Home > Technical (L322) > Restricted Performance
j_rov
I’ve just had the dreaded message flash up and clear lots of times today, sometimes a flicker and sometimes long enough for the OK to clear message to pop up. There’s no bong and no loss of power. There’s no codes logged either!
Any ideas?
2010MY 3.6
Thanks __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #481923 26th Jun 2018 6:13pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Quite likely to be one of the two top intercooler to intake manifold hoses has a split. Very common problem. Often the near side hose, underneath the short piece of webbing.
There are other hoses that could also cause the message, but these are the place to start.
Another cause could be the wires to the top of the front struts (adaptive suspension). They chafe and short to earth. Straightforward enough to splice in some replacement wire to fix. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #481925 26th Jun 2018 6:33pm
j_rov
Thanks. All hoses replaced in April so hopefully not them...
Will check out suspension turret wires... __
Land Rover History:
1976 Series 3 2.25
Post #481927 26th Jun 2018 6:40pm
j_rov
I found one of the wires in the suspension turret that looked previously repaired was showing some bare wire through the insulation. Quick resplice and solder this morning and message seems to have gone.
Fingers crossed... __
Land Rover History:
1976 Series 3 2.25
Post #481977 27th Jun 2018 11:50am
steveball
Good result. Quick to fix and free!
Smile Current: 2010 Range Rover L322
Post #482039 27th Jun 2018 8:58pm
