Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
A gearbox oil change is not included in the Land Rover Service Schedule - according to them it's sealed for life. It's "only" the gearbox designer / manufacturer who recommend oil changes ! Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
17th Jun 2018 12:08pm |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 |
Thanks Paul, I thought as much, seems like it is recommended on here to do it. I will ask my
17th Jun 2018 12:23pm |
I should have said get all ecu fault codes read by someone & be sure the gearbox is working generslly ok before organising the oil change.
17th Jun 2018 1:19pm |
I am purchasing an IID tool off of Dan, will that be of any use to check for Gearbox codes.
17th Jun 2018 2:23pm |
IID tool is ideal.
17th Jun 2018 2:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
15th Aug 2018 2:09pm |
My gearbox oil change was not without its trials and tribulations. 4.7 litres out, and, eventually, 5.5 litres back in !
15th Aug 2018 2:28pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Excellent write up again joe90 this is on my list to do too so will follow the guide.
15th Aug 2018 5:32pm |
No issue, no leaks, probably didn't need doing....the one in there was fine, nothing as bad as the one in RRPhil's picture
15th Aug 2018 5:45pm |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 |
The mechatronic sleeve only seems to leak after the car has been stood unused for three or four days. If you use the car regularly you may never notice or care. I guess that's because the oil gradually moves from the torque converter to the sump over an extended period, eventually filling it to the level of the sleeve. |
15th Aug 2018 5:51pm |
Well for the sake of £10 seems like a no brainer whilst your in there. Thanks Current 2007 TDV8 Vogue Buckingham Blue |
16th Aug 2018 5:53am |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
Thank you all for this thread. Very good contributions here Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
16th Aug 2018 6:20am |
Joe90,
16th Aug 2018 8:35am |
I drained with the oil temp at @ 40 degrees
16th Aug 2018 10:47am |
