![]() | Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
@ Highroller, don't forget to tap out the threads |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
My threads were all perfect & had zero problems removing or replacing the bolts. Of course condition will vary with usage/environment. They will probably be OK. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Update so far. Oil drained & as per Pawl's comments good to see a reddish colour with no debris on the magnets (Removed 5.5 ltrs).
Yes, when you are ready with bottles of Lifeguard under the car and your pump, and you have got as much in as you can with the engine off, start the car, then dive under and start pumping. You also need to monitor the transmission oil temp, as the fluid level check should be done at between 30 and 50 degrees (not below or above). As soon as it starts dribbling out again, get into the drivers seat, foot hard on footbrake, and slowly work your way through the gears, 3 seconds in each. Also go across to command shift (manual) and up into 3rd then down to 2nd and 1st ( I got quite a clunk when going into 1st!). Once done, back underneath and pump some more. When it starts dribbling again put filler plug back in. Job Done |
You also don't have that much time before the oil temperature moves out of range (may be better with the diesel, but the temperature rises quickly with the supercharged).
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Can anyone tell me if the Mobil 1 oil for the 5hp24 would cause this box a problem? I bought 20 litres of the stuff for my old 4.4 and have a good 10 l left and it wasn’t cheap Current stable:
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
My opinion is if it’s the correct spec then it’s fine, others may have a different opinion. Oil make debates are always interesting’ and almost always based on antidotal evidence or pure conjecture and bias to a particular brand.
The 5HP24 has different oil spec I'm afraid. I wouldn't use anything apart from the correct ZF lifeguard fluid. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6765 ![]() ![]() ![]() |
I don’t think they would do this unless you specifically requested it, as they say it’s sealed for life.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1807 ![]() ![]() |
DONT put it into a 6HP box ![]() ![]() |
Ok so I have to buy 7 1 litre bottles? I see on eBay kits with the plastic filter for £190 all in with 7 bottles of zf?
Febi oil is decent stuff. Used it a few times over the years when I've struggled for Ravenol stuff |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Had my transmission oil changed over 3 years and 15000 miles ago at my local indy. Noticed in the last year or so that gearbox was reluctant to change up when starting from cold but otherwise OK. Also noticed more recently that getting oil onto drive but not excessively. Whilst underneath the car, sorting out my rear subframe, noticed a drip from the gearbox drain plug.
