![]() | Home > Technical (L322) > 2011 4.4 tdv8 alternator problems |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
what battery have you got fitted? There is nothing that can't be fixed with a hammer😜😜
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi , its a Advanced AGM 020XD Battery 950 cca 2015 4.4 AB
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Is it the 12.5v reading that is worrying you?
Thanks Mike, the reading on the IID tool was my main concern so that helps. As i say, i never have problems starting and the reason i changed batteries was it wouldn't always run the FBH and I some times got air suspension warnings. After battery change , 6 months ago, all has been good , until recently but suspension is now a different issue and I only happen to notice the IID tool display while looking at live values.
Just an update, put car on Ctec last night and it read 13.2 ( all bars full on display) this morning. I checked with IID and it read12.7V
if its reading about 14 and a bit volts with the engine running then you don't have an alternator issue |
Thanks Mr Monkey |
you can monitor with the radio screen and the 753 hidden menu as you are driving along. There is nothing that can't be fixed with a hammer😜😜
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Oooh a secret screen??? |
Hi bish, on the 2007 VSE I had it was main menu, press middle of screen near the top and the menu would appear and ask.for the code , which was 753, i haven't tried it on my 2011 yet. Plenty of info if you use the search function on here sir. 2015 4.4 AB
Yep same method works on the 2010-> |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
John might be that battery you got a good deal on a while back...
Hi Greg , that did occur to me but the IID tool is still shown 14.2V so I'm hoping all is ok. When i got the new battery I tried to select the corresponding one from the list on the IID tool but there wasn't one as powerful as my new one so i choose the closest one. On reflection i have now changed it to unknown or whatever term GAP used. I also told the car ( via IID tool , not verbally ) that i have installed a new battery so i will see what happens.
is it 14.2 with the engine off?
