Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
seewolfe Member Since: 22 May 2018 Location: Huntingdon Posts: 8 |
Latest update.
3rd Jun 2018 6:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
You can change the startup screen in Factory settings, pin to get in is usually 126 but maybe something else, google the head unit you have to find it... you can also use a custom one... a few I have can be found at this link which I will leave up for a while...
4th Jun 2018 3:41pm |
Cheers.
4th Jun 2018 8:21pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
fit one of these
14th Jun 2018 7:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
first link is dead... ... - .- -.
14th Jun 2018 7:54am |
Thanks - I did see that unit in an earlier thread but IIRC it's about £120 so decided for now that the head unit is staying!
14th Jun 2018 8:19am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Coming in late in the day here but why can’t you use dsp? If you look at my nbt thread you will see someone recommended a realer interface with and android tablet and app which can tell the dsp to run all the time (rather than timing out) and accepting a line in signal from your rca outs. This will give you a far better system than connecting directly to the speakers as the amp will handle the crossovers correctly. Cheers Current stable:
1st May 2019 5:51pm |
Cheers. I did see that but its moot for me. The dsp has stopped working now - I get the 9 soft beeps from hell and no audio.
2nd May 2019 6:48am |
Oh no what eonon did you get I just bought one 🤔 I bout the CarPlay interface so will use that most of the time I’m sure Current stable:
2nd May 2019 10:12am |
I purchased the GA8201A
2nd May 2019 3:35pm |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
Oh oh. I bought the Eonon ER9201, i havfitted it and all seemed to be working as it should except i was unable to find where to connect the radio aerial, but now the funstarts first when i first started in the morning the steering dropped right down and the memory in my seat seemed to have forgotten where it was supposed tobe, went for a drive and the enjine ran hot, let it stand till it cooledand checked coolant, full up. Checked battery and the battery wasabout 11 volts soi put it on charge over night,next morning same thing, steering dropped and enjine ran hot, let it cool and went for a run, temperature cool and steering remembered its position. Went for another run later and all seemed ok but then i noticed the idle speed was up over1000 rpm,????
29th May 2019 2:31pm |
Just try one thing- disconnect the little canbus box it can be with all should work except steering controls and report back if it fixes it Current stable:
29th May 2019 5:56pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
The car reving high sounds like a battery drain/low battery voltage to me. Just disconnect the little box first and see if that changes things.
29th May 2019 8:04pm |
Morning all, thanks for the replys, i don,t know if this makes a difference but i have the old head unit in the glove box and i only used the long harness to reach the rear, the two short harness have not been used, yes my battery is draining as i have to keep charging it up. I will get another battery and seehow it goes. |
30th May 2019 1:12am |
