Home > In Car Electronics (L322) > Dash camera fitment |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
I installed my 805 camera today in my 2008 L322 and found power from the GW (+) and NB (-) wires to the interior mirror. These are live when ignition is on and fused by a 5A (fuse 6 in the passenger compartment fuse box). In the sunglass compartment there are 2 bolts fixing the console to the roof, also one clip on each side and two in the rear of the console. The clips sit very tight so you ned some force but also be careful. With the console out of the way, it is easy to find the cables to the mirror. I spliced into the cables a couple of cm from the plug but I advice to do the splice at least 7-8 cm away as the splice then will be under the roof lining and not close to the mirror, not much space for extra cables there... Two 20 cm long pieces of copper wire welded to the power adapter and to the cables to the mirror, all connections insulated. The rather large 12V to 5V adapter can easily be located in front of the sunglass compartment. "Plentraktoren/Garden tractor": 2008 L322 TDV8 "Project": 1990 90 County 300tdi |
3rd Jul 2016 12:30pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 |
Good info there many thanks 👍 Many thanks
3rd Jul 2016 3:58pm |
Andrey2123 Member Since: 23 Feb 2018 Location: Saint-Petersburg Posts: 8 |
I needed the DVR to turn on when the ignition is turned on. "+" for adapter took the fuse 6, the unit in the passenger box.
18th May 2018 4:18pm |
