![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Exactly. Creates the same resistance the heating element creates. The case is a heat sink. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I think I was getting resistors and capacitors muddled up or something else yet unknown to man |
I understand. I have the weakest knowledge of electrical engineering in even the simplest forms. The only lab in physics that I had no grasp of. |
How much did you pay for it ? |
spgmcb Member Since: 11 Jun 2015 Location: Kent Posts: 17 ![]() |
£50 posted from Germany on e bay. |
Thats good as i paid around £100 |
That may have been a BMW part, Behr makes the BMW parts so I was happy to use their part which turned out to be BMW anyway. It worked out cheaper than the e bay mod with no cutting or leaking gaskets as its fits perfectly, for me also peace of mind using a oem part. |
Heres mine from earlier in the thread
That's the one, fits perfectly, all you need to do is tape up the wire to the unused heating element and store it under the engine cover. No dash warning lights. |
This one ?
No, the p and p and cost of that one is a lot more.
Yep sorry i found yours and then linked the wrong one |
Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39 ![]() ![]() ![]() |
Just completed the thermostat mod, used the 88 degree Stat. Engine feels much smoother and a little quieter when idling. My thermostat had packed up anyway was taking ages to get upto temperature. Very happy with the mod, and a big thanks to the people that have posted on this thread. |
Jmckenzie295 Member Since: 18 Apr 2018 Location: Glasgow Posts: 17 ![]() ![]() ![]() |
I am definitely thinking of getting this done. Probably will go with the BEHR as as far as I can see is a straight swap, correct?
