Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 10 of 12 <123 ... 9 101112>
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Exactly. Creates the same resistance the heating element creates. The case is a heat sink.
Post #463664 7th Jan 2018 6:16pm
holidaychicken
I think I was getting resistors and capacitors muddled up or something else yet unknown to man Embarassed
Post #463665 7th Jan 2018 6:22pm
doclees
I understand. I have the weakest knowledge of electrical engineering in even the simplest forms. The only lab in physics that I had no grasp of.
Post #463673 7th Jan 2018 7:00pm
spgmcb
A few weeks ago I fitted a BEHR (TI 32 88 ) thermostat to both of my L322, one is a LHD 4.4 V8 NAS spec and the other is a RHD 4.4 V8 Japanese spec with LPG. Behr makes the BMW 740D Thermostat (OEM NUMBER 11512248542 ) and if you look closely at the BEHR (TI 32 88 ), you can see where the BMW mark has been removed to sell as a Behr original part. The BEHR (TI 32 88 ) is a straight swap for original 4.4 V8 thermostat, no extra gaskets or modification needed as some listed on ebay. As this thermostat has a lower temp, there is no need for the heating element which is blanked off, I was concerned about this but everything I have read indicates the lower temp thermostat does not need a heating element to force the thermostat to open. I taped up the old wire leading to the heating element and stored it under the engine cover. No warning lights when running without the heater element hooked up and the engine sounds much happier, hope this helps.
Post #473524 22nd Mar 2018 11:08pm
holidaychicken
How much did you pay for it ?
Post #473532 23rd Mar 2018 12:03am
spgmcb
£50 posted from Germany on e bay.
Post #473533 23rd Mar 2018 12:39am
holidaychicken
Thats good as i paid around £100
Post #473552 23rd Mar 2018 9:37am
spgmcb
That may have been a BMW part, Behr makes the BMW parts so I was happy to use their part which turned out to be BMW anyway. It worked out cheaper than the e bay mod with no cutting or leaking gaskets as its fits perfectly, for me also peace of mind using a oem part.
Post #473609 23rd Mar 2018 4:01pm
holidaychicken
Heres mine from earlier in the thread
http://www.fullfatrr.com/forum/topic39362-30.html
Post #473622 23rd Mar 2018 6:09pm
spgmcb
That's the one, fits perfectly, all you need to do is tape up the wire to the unused heating element and store it under the engine cover. No dash warning lights.
Post #473914 26th Mar 2018 12:34pm
holidaychicken
This one ?
https://www.ebay.co.uk/itm/BEHR-Thermostat...SwIUxahPRy
Post #473994 26th Mar 2018 11:04pm
spgmcb
No, the p and p and cost of that one is a lot more.
E bay item eBay Item No. 381967284855, genuine part, boxed with the correct hologram.
Post #474047 27th Mar 2018 2:11pm
holidaychicken
Yep sorry i found yours and then linked the wrong one
Post #474063 27th Mar 2018 5:03pm
Deltaevo
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
Just completed the thermostat mod, used the 88 degree Stat. Engine feels much smoother and a little quieter when idling. My thermostat had packed up anyway was taking ages to get upto temperature. Very happy with the mod, and a big thanks to the people that have posted on this thread.
Post #478172 12th May 2018 6:06pm
Jmckenzie295
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I am definitely thinking of getting this done. Probably will go with the BEHR as as far as I can see is a straight swap, correct?
My question is, I have lpg running, will this affect the automatic switch over from petrol to LPG? to clarify, the lpg won't run when the engine is cold and generally switches to it when the temp gets to the top of the blue.
Should this just work as is, or would something have to be changed?
Cheers
Post #479100 21st May 2018 11:05pm
