Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked
Page 2 of 4 <1234>
Bluegreygreen Rangie
Australia
Crashtestkev wrote:
Guys I’ll be looking to purchase a bt IIDTool soon but am trying to understand the costs.
The price or the tool is fine, then to flash the ecu costs?
If I want to remap I have to buy fast lane and buy a remap file, and then if I want to egr delete I have to buy that file too? If I want to calibrate the suspension there is a cost too?
I’m having trouble understanding fully what’s included and what the extra costs to do what I want will be
Anyone help?
Talk to BAS Remaps, He will do your map and egr delete in one file for you.. actually i think it was two but all in succession with the egr delete done first.. He may even give you a slight discount if you do both together . I had my 3.6TDV8 done (remap and egr delete) and been perfect so far. I would not waste your time with any other company
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #469132 18th Feb 2018 6:18am
GGDR
Just getting back to this thread.
I've been a bit pushed for free time (been away on hols too) and finally after like two months, finally got my IIDTool working today fully thanks to Patrick at GAP. (Thanks Patrick!)
Any pointers for newbie on how to edit the CCF would be most welcome!
Any top CCF edits most welcome too!
I also have this error code relating to EGR
any tips?
Thanks guys,
Greg Cheers, Greg
Post #470750 2nd Mar 2018 8:47pm
kbald
Bit of info on this post about it
http://www.fullfatrr.com/forum/post397899.html Current 2007 TDV8 Vogue Buckingham Blue
Post #470755 2nd Mar 2018 8:56pm
GGDR
ah thanks kbald, I posted before search!
A quick 5min skim over those and it's mixed opinion. Many say it's nothing but IanT599 says it'll cause over-fuelling.
I'll do some more reading. Cheers.
. Cheers, Greg
Post #470759 2nd Mar 2018 9:02pm
kbald
Good luck with it. Thumbs Up Current 2007 TDV8 Vogue Buckingham Blue
Post #470760 2nd Mar 2018 9:03pm
GGDR
Just a bump to an earlier question:
I like the numeric speedo hack, DRL's - any top CCF edits recommended?
. Cheers, Greg
Post #471737 8th Mar 2018 10:18pm
single press 'superlock'
beep on lock/unlock ... - .- -.
Post #471738 8th Mar 2018 10:20pm
GGDR
Ah - thanks Stan. I like those two.
So do I just go into that menu and change it? I have this probably wrong idea that I have to upload a file.
I've not spent too much time with my IID.
Greg Cheers, Greg
Post #471740 8th Mar 2018 10:28pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Go in ... change setting ... follow instructions ...
... when done reset clock to correct time - and any audio settings back to what they were Smile What do I put here then?
Post #471743 8th Mar 2018 10:58pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Yep, having done my first CCF change this week for the digital speedo, it is very simple Greg.
Just go into Car Config in the IID tool, it will first backup your CCF if you haven't already, and then it gives you a list of parameters for each ECU that it can change, with drop downs on each for the possible values you can select. Update what you want, and when finished you tell it to upload your changes in a single hit, and it will upload a complete modified CCF file at the end when you're ready. The tool will prompt you to turn the car on/off and stat/stop the engine at the end. The IIDTool does have 2 CCF editing menus, I forget the exact language but something like "supported features" and "features in beta testing". I played it safe and just looked in the "supported features" that is listed first!
But as GAC23 says, once you've uploaded the CCF changes the date/time get reset on your dash and centre screen (and the audio settings reset apparently, but I didn't notice that!). The date/time gave me a bit of a shock and I was sure I'd broken something, but you just have to change them via your central touch screen afterwards.
Post #471746 8th Mar 2018 11:16pm
GGDR
Amazing, thanks GAC, thanks Paul.
Any more any top CCF edits anyone?
. Cheers, Greg
Post #471759 9th Mar 2018 7:27am
GAC23
You might like to edit the suspension height - assuming you've fitted bigger wheels.
And I always find the one touch windows need resetting after a CCF edit. What do I put here then?
Post #471768 9th Mar 2018 9:10am
GGDR
Cheers GAC.
So I thought I'd give it a go this morning....
My battery's in it's twilight but starts fine every time, even if I watch a bit of Top Gear on Dave for a bit with the engine off.
But the CCF edit really drained the battery, started at 12.9v and, while doing it's auto on-off-on-off sequence, I watched it drop and drop - 12.2 then 11.8, 11.5 - got really worried I'd killed it.
Then IID said failed upload then a bunch of errors came up on the dash. I thought there's no way it would crank on the last reading of 11v but thankfully it fired into life.
Hindsight's brilliant and I remember reading somewhere that a low battery is a bad idea for IID work. Should have remembered that before I steamed in.
It runs, got me to work but cruise control and some other functions are unavailable.
I'll have to wait for DRLs while I look at batteries!
. Cheers, Greg
Post #471775 9th Mar 2018 9:42am
you should always have the engine running when editing the ccf or suspension.... ... - .- -.
Post #471778 9th Mar 2018 10:00am
GAC23
Upload failed is normal. Don't worry, it hasn't failed.
Also normal - well, mine does it - is the bunch of errors on the dash.
To sort this I ... switch ignition off ... get out of car ... lock & unlock ... then start car.
And to get the fairy lights on (no lights at rear) is BCM Body Control >> DRL standard >> Active.
And - if you need to - set DRL Canadian and DRL Scandinavian to Disabled.
Have you changed wheel size?
If you have, IPC Instrument Pack >> Rolling Radius ABS mm needs to be correct to keep your speedo accurate.
According to the very helpful Patrick @ GAP, the other wheel / tyre size options don't affect the speedo - but I changed all of these too.
To help me work out the rolling radius, Patrick sent me this:
The 390 mm is based on a Cooper Zeon LTZ in a 285/60-18.
The tire itself is stated to measure 31.46 inches which equates to 799mm or 399.5mm radius.
In order to account for the weight of the car compressing the tire sidewalls I put a mark on the tire perpendicular to the ground and also marked the ground.
I then rolled the LR3 forward so the mark on the tire did 1 full revolution and then marked the ground again when the mark on the tire was perpendicular to the ground again....then measured between the two marks on the ground and that came to 780mm or 390 radius.
Being lazy, I used this link instead: http://paws.kettering.edu/~amazzei/tire_calculator.html
Checking speedo against those speed signs which show your speed suggests it's ok. What do I put here then?
Post #471780 9th Mar 2018 10:04am
Page 2 of 4 <1234>
