![]() | Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Just getting back to this thread.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Bit of info on this post about it
ah thanks kbald, I posted before search!
Good luck with it. |
Just a bump to an earlier question:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
single press 'superlock'
Ah - thanks Stan. I like those two.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Go in ... change setting ... follow instructions ...
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Yep, having done my first CCF change this week for the digital speedo, it is very simple Greg.
Amazing, thanks GAC, thanks Paul.
You might like to edit the suspension height - assuming you've fitted bigger wheels.
Cheers GAC.
you should always have the engine running when editing the ccf or suspension.... ... - .- -.
Upload failed is normal. Don't worry, it hasn't failed. Also normal - well, mine does it - is the bunch of errors on the dash. To sort this I ... switch ignition off ... get out of car ... lock & unlock ... then start car. And to get the fairy lights on (no lights at rear) is BCM Body Control >> DRL standard >> Active. And - if you need to - set DRL Canadian and DRL Scandinavian to Disabled. Have you changed wheel size? If you have, IPC Instrument Pack >> Rolling Radius ABS mm needs to be correct to keep your speedo accurate. According to the very helpful Patrick @ GAP, the other wheel / tyre size options don't affect the speedo - but I changed all of these too. To help me work out the rolling radius, Patrick sent me this: The 390 mm is based on a Cooper Zeon LTZ in a 285/60-18. The tire itself is stated to measure 31.46 inches which equates to 799mm or 399.5mm radius. In order to account for the weight of the car compressing the tire sidewalls I put a mark on the tire perpendicular to the ground and also marked the ground. I then rolled the LR3 forward so the mark on the tire did 1 full revolution and then marked the ground again when the mark on the tire was perpendicular to the ground again....then measured between the two marks on the ground and that came to 780mm or 390 radius. Being lazy, I used this link instead: http://paws.kettering.edu/~amazzei/tire_calculator.html Checking speedo against those speed signs which show your speed suggests it's ok. What do I put here then? |
