![]() | Home > In Car Electronics (L322) > IID Tool newbie - I'm hooked |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Nino,
I have just re-tried, but switching ignition on or off does not affect iid voltage reading .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
Mike . i'm pretty sure these are the reason for your readings,
Thanks Stan, that makes sense, but Nino says he connects his Ctek when using iid?
i always run the engine, it's a diesel so it don't cost much.. |
Thanks for your reply Nino.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
The car can’t be running when flashing ECU. So battery needs to be good or use inline charger or jump leads and a running car works 4.2 SC - sold , now bought back
certainly true for an ecu flash , but for ccf and height adjusts then run the engine.. ... - .- -.
