Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Greg,
31st Dec 2017 8:15am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Thanks Mike.
31st Dec 2017 8:48am |
Does this picture help?
Hmmm yes I saw that in the WM but it doesn't seem to show the pipe. Nor the oil suction pipe (or at least I can't spot it).
31st Dec 2017 8:58am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Change over valve for the turbo, the one which sticks..... There is nothing that can't be fixed with a hammer😜😜
31st Dec 2017 9:47am |
Greg,
31st Dec 2017 10:35am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, i had leak in front and after long search located the culprit, it was plug on the top of the oil pump. What I did was to loosen the plug as far as will go apply some silicon and tigtend, problem solved. If not there, leak may be from steering pipe/connection.
31st Dec 2017 11:41am |
Thanks guys.
31st Dec 2017 12:27pm |
Problem with front of engine leak is that when the fan is blowing it moves oil all over the place. |
31st Dec 2017 12:50pm |
A bit of progress with my on-going oil leak search, was under the car at the weekend and found this pipe to be quite wet, at least at the bottom bend.
2nd Jul 2018 8:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
that looks like the old turbo drain pipe Greg before its modification...... ... - .- -.
2nd Jul 2018 8:40pm |
yes that's right Stan,
2nd Jul 2018 9:35pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
if there is only 1 pipe for the turbo drain then the updated drain has not been fitted because it has 2 pipes going to different spots on the sump. |
3rd Jul 2018 2:08am |
3rd Jul 2018 10:14am |
