![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Greg,
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Thanks Mike.
Does this picture help?
Hmmm yes I saw that in the WM but it doesn't seem to show the pipe. Nor the oil suction pipe (or at least I can't spot it).
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Change over valve for the turbo, the one which sticks..... There is nothing that can't be fixed with a hammer😜😜
Greg,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Greg, i had leak in front and after long search located the culprit, it was plug on the top of the oil pump. What I did was to loosen the plug as far as will go apply some silicon and tigtend, problem solved. If not there, leak may be from steering pipe/connection.
Thanks guys.
Problem with front of engine leak is that when the fan is blowing it moves oil all over the place. |
A bit of progress with my on-going oil leak search, was under the car at the weekend and found this pipe to be quite wet, at least at the bottom bend.
Has anyone ever had a leak here before? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
that looks like the old turbo drain pipe Greg before its modification...... ... - .- -.
yes that's right Stan,
Can you tell from this photo if it's been done? Bottom of my pipe is quite wet. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
if there is only 1 pipe for the turbo drain then the updated drain has not been fitted because it has 2 pipes going to different spots on the sump. |
,Nino |
