![]() | Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!! |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
My oil cooler leak turned out to be the gasket between the oil and coolant in the cooler, and cost me around £15.
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
A grand?? I hope not.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3809 ![]() ![]() ![]() |
Gumball3000,
Yep, another forum member has been quoted £947 to replace the oil cooler and flush the coolant system. I was quoted around £340 just for the replacement cooler since I was replacing it myself, so if you got yours for £326 all inclusive, then you got a bargain ![]() However, the failed gasket was only £15.......so I didn't need to replace the whole cooler. Mike |
Wonder if yours is a different cooler on a 2011 car ? Just checked my invoice and cooler for my 2004 was £110 plus vat Not Galway but Balmoral green actually
It is a completely different unit , unique to the 4.4 tdV8. G reg 2.5VM Vogue Portofino red 1991- 1999
Good spot Baltic, I never thought to check we were discussing the same variant! |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
Got car back today all sorted new oil cooler + all seals replaced. RAC warranty is picking up the bill. |
Hope you get to enjoy many trouble free miles now.
Lets hope so , no i didnt see the invoice . But they said they would send me a copy for my records once it all sorted. |
**UPDATE**
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Gumball, had the same thing go on mine replaced under warranty, but from memory it was about £800 all in.
Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30 ![]() ![]() |
Mines in at the moment having oil cooler replaced great local independent £350 all in getting gearbox flushed and new filter fitted at the same time so car should be good as new for our drive down to spain on sat
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Hi, I had mine done at the stealers £947 took it back after a week with oil still spotting the driveway, they dropped the undertray and showed me it was just residual oil still coming down from the bell housing. I took the car to an IOM soft wash after another week and had under chassis wash which has cleaned it all up now.
