Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!!
Page 6 of 7 <1234567>
faz2kool
United Kingdom 2010 Range Rover Vogue 4.4 V8 Stornoway Grey
Is it a big job to get to the sump. The local indy was saying it's a big job and takes alot.of time so he cant do it straight away..I could wait for him to save some money for a couple of weeks or let land rover have a look, diagnose and then repair..???
Not sure ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
BMW 325i - 1992 (E30)
Post #532169 26th Oct 2019 1:24pm
GGDR
I think it is.
You probably want to do the oil drain mod (turbo #2) if you haven't had it done at the same time.
I am thinking a lot of stuff (like the front diff) have to come off for both jobs.
Is Green Oval Garage far from you?
. Cheers, Greg
Post #532171 26th Oct 2019 1:48pm
faz2kool
Green oval garage is not too far.
Have u had work done from them? ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #532179 26th Oct 2019 3:45pm
GGDR
Not me but people rate them here.
AJGalaxy2012 had the turbo drain done by them.
. Cheers, Greg
Post #532180 26th Oct 2019 3:54pm
GGDR
https://www.fullfatrr.com/forum/post493778.html#493778 Cheers, Greg
Post #532181 26th Oct 2019 3:55pm
GGDR
https://www.fullfatrr.com/forum/topic48944-30.html
BTW I do think you should speak to somebody like Green Oval, you need people who are not only versed in Range Rovers but the 4.4TDV8. It's not the driest of engines, oil seals here and there can go. I've got an as yet unfound oil leak which is dripping down onto the skid tray but it's not the sump. I think second opinion / investigation would be warrantded.
. Cheers, Greg
Post #532183 26th Oct 2019 4:07pm
faz2kool
So landrover ring me up today after doing a diagnostic and they seem to think it's the oil pump itself that's leaking and they quoted me over £3k to have this sorted. After some discount they got the price down to £2600.
Claim to be a 3 day job?
I dont see why but what are your thoughts. Price seems very expensive. ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #532428 28th Oct 2019 1:32pm
DrRob
Take it to Green Oval for a second opinion and a more realistic price Thumbs Up Banging Head Banging Head Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532431 28th Oct 2019 1:42pm
Baltic Blue
Looking at the job description in the workshop manual PDF it’s a full front end strip down job, belts pulleys, fan etc, just to get to it.
Get a quote from Green Oval, bound to be cheaper than JLR .
Post #532432 28th Oct 2019 1:42pm
faz2kool
Just rang them, waiting for Brian to get back to me.
Shocked with LR price for Labour. Ouch ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #532434 28th Oct 2019 1:51pm
DrRob
I would not trust a main dealer these days full stop. Independent specialists have a vested interest to be the best and retain / be referred customers. I am taking mine over an hours drive away in Reading to have Rovertune's opinion on something. I would not go anywhere nr local main dealers Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532435 28th Oct 2019 1:53pm
faz2kool
Just heard back from Brian @ Green Oval Garage. Top Bloke.
Have to say, very good advice over the phone. Much better than the main dealers. Explained there is so much process in replacing the Oil Pump and the Sump. Both would require Subframe removal, suspension and complete front end. This would also mean having to replace oil filter and oil, get tracking done, get air con regassed etc etc.
Also said he would have a look to make sure as a second opinion as the Dealers video was not very clear.
Have booked in with him in a few weeks time. See how it goes. ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #532448 28th Oct 2019 2:53pm
faz2kool
Update from Brian at the Green Oval Garage
He seems to think the leak is coming from the CamShaft Seal and has supplied me with the following pics before and after a 60mile run.
<img>
<img>
I have to say, these guys are amazing compared to Land Rover Dealers. Much more indepth analasys and evidence. Cant see the dealers driving the car for 60 miles etc.
Just want to say thanks to those who recomended Green Oval. Just waiting for replacement parts and then for them to check again to see if the leak has been cured. ------------------------------------------------------
RR 4.4TDV8 2010
Mini JCW 2006
Post #533945 12th Nov 2019 6:04pm
faz2kool
RR 4.4TDV8 2010
Mini JCW 2006
Post #533946 12th Nov 2019 6:05pm
nino_nino
this is where mine oil pump had a leak, plug on top of the oil pump.
Nino, Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #533951 12th Nov 2019 6:46pm
