Home > Technical (L322) > Fairy lights round Headlights (DRLs - not)
supershuttle
Well thanks to Stan and the IDTool I got the fairy lights round the headlights to come on with the ignition, I know they are not DRLs but I like the look and Christmas is coming so fairy lights are appropriate. Very Happy Geoff
Post #456024 3rd Nov 2017 3:36pm
not to keen on fairy lights...
Mr. Green Wink ... - .- -.
Post #456029 3rd Nov 2017 4:38pm
supershuttle
I had to wait until it was dark:
Engine running no other lights on.
Perfect Thumbs Up Geoff
Post #456038 3rd Nov 2017 6:06pm
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Looks good Thumbs Up
Do all the 2010-12 models have these lights, and do they all need turning on using the IIDTool? I rather like them too...
Chris
Post #456050 3rd Nov 2017 8:18pm
supershuttle
Yes they are L322 2010 onward, I used an IDTool, there may be other ways Geoff
Post #456051 3rd Nov 2017 8:24pm
carpcat
I assume they’re just for effect rather than any functional use?
Chris
Post #456052 3rd Nov 2017 8:28pm
Clabs
Hi Geoff - I quite like the idea of these coming on with the ignition.
What setting did you change to achieve this?
Cheers, Mark
Post #456056 3rd Nov 2017 9:03pm
mjdronfield
Carpcat, they are the normal front sidelights...... set to come on with ignition.
I just turn my sidelights on if I want them.
I like them on. You’d never use them if you left the lights on Auto though.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #456061 3rd Nov 2017 9:43pm
supershuttle
You can use the sidelight switch but that will also turn on the rear lights as well, however if you don't want this and you just want the front side lights to come on with the ignition and with the light switch set to off simply use the IIDTool to turn on DRLs and also enabled both Scandinavian and Canadian modes. Worked for me. Geoff
Post #456064 3rd Nov 2017 10:44pm
mjdronfield
Indeed, I was more replying to the query about them being for effect than anything else. If you don’t have a 2010 onwards, you might not realise they are the front sidelights that was all.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #456066 3rd Nov 2017 11:12pm
carpcat
I always have my lights on auto so this probably explains why I’ve never seen them....what happens if you turn them on with ignition using the IID Tool and turn the light switch to Auto? Do the fairy lights still light up or do you need the switch turned to off still? Chris
Post #456071 4th Nov 2017 7:29am
supershuttle
Auto just works as normal, fairy lights just stay on all the time. Geoff
Post #456073 4th Nov 2017 8:18am
mpirie
I used the IID tool to turn on the dipped beam headlights as DRL's.....the fairy lights are pretty weak for a DRL.
The light switch is left on auto, so I know people can always see me.
Mike
Post #456080 4th Nov 2017 10:28am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
DRL were made law in 2011 so all vehicles have to have them fitted , I guess LR decided to get in early , I really like them on cars but we were big Volvo fans when I was growing up so that may explain that Laughing
Post #456104 4th Nov 2017 11:51am
supershuttle
Driving the car today, everything fine fairy lights on but when the dipped headlights automatically switched on - they stayed on (tail lights went out) , so a bit more work to do. Very Happy Very Happy Geoff
Post #456233 5th Nov 2017 2:24pm
