![]() | Home > General > What Did You Do In Your Full Fat Today |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
Fitted a fullfatrr.com sticker to the new TDV8
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Drove the bride and groom from the church to the reception in style...
steeplejack Member Since: 11 Apr 2016 Location: Gloucestershire Posts: 19 ![]() ![]() |
I got the air-con regassed after reading a few posts in the forum suggesting that the irritating noise I could hear when the air con was on, which varied with the engine revs, could be caused by low gas pressure. Result |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Fitted Varta 020 battery. Tight squeeze but got there. |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 ![]() ![]() |
Gumball V.Nice |
Thanks m8 , I liked the old girl that much i thought why not. |
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
Remember it is also a dehumidifier and will keep your cabin condensation free. Plus, never turn off the climate, you will dry out the seals and that can start to get expensive. Also, hate to say this, if you have lost the gas it has escaped from somewhere, did you get an aircon company to test it before getting a refill? Quite often the seal at the fill point that fails, which is a £5 part. If you find it is making a noise again in a couple of weeks get a local specialist out. Porsche 911 (996) 2015 BMW 5 Series Touring Not got a LR of any kind at the mo, and got itchy feet. |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 791 ![]() ![]() ![]() |
Drove to dat der lundun and back with only one ' water in fuel' message which I cleared. ( See maintenance/ mods section ). Have ordered replacement sensor now to see if that stops the problem message. Trip showed average of 32 mpg for 420 trip. |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Picked this up for a friend (the porsche)
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
front arm replaced and gearbox fluid and filter done , enjoying the silence |
Replaced the front drop links.
we are similar people then Gizze , the slightest knock irritates the hell out of me pal |
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 ![]() ![]() ![]() |
Cleaned the MAP sensors today, although they were surprisingly clean already. Whilst I had the engine cover off I noticed another leakage from a the end of a hose. The hose clip seemed to be pretty loose so cleaned it up and nipped it tight. I’ll keep an eye on it.
