Home > General > What Did You Do In Your Full Fat Today
Page 255 of 377 <123 ... 254255256 ... 375376377>
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Turned 200000kms!!!
Post #452066 25th Sep 2017 3:53pm
Had the front brakes apart today, due to annoying squealing at low speeds (when braking).
Everything working as it should, even wear on both sides with both wheels, plenty of pad, discs looking fine.
Followed this video, and used some AUDI brake grease (came with OEM Audi brake parts) on all the metal contact surfaces after a good cleanup. Couldn't undo the carrier bolts (16mm) this time around, they were in there tight, I'll have another go when I get a bit more ground clearance one day, to get good leverage.
Now to see if it has sorted the squealing
EDIT after a prolonged test drive, all quiet on the braking front Very Happy .
Post #452155 26th Sep 2017 2:20pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Hi joe90
I’m in the process of doing a front wheel bearing and just to give you a heads up those 16 mm carrier bolts are a real pain.
I lost half a day trying to get them out I broke several sockets of different size and quality.
In the end was a dewalt nut gun and an impact socket to shift them.
Post #452164 26th Sep 2017 5:34pm
fisha
Front drivers side driveshaft out, disassembled, cleaned and refitted with new rubber boots along with a new lower arm. All for an MOT tomorrow ....
however, during the process, broke the drop link ball joint .... aaaahhh! cue a mad dash for a new one ... all fitted and back together now.
Better bleedin pass! V8 or else ...
Post #452192 26th Sep 2017 8:10pm
fisha
Well, washed it , hoovered it, popped the bonnet and topped everything up. Drive to the mot station, parked, noticed leaves stuck in the drain areas at the bottom of the windscreen, popped the bonnet .....
Bonnet cable snapped .... Aaaahhhhhh.
Had to sheepishly admit the issue. The guy was brand new and said of wee can get it popped open be would test it and then let me go home with it to fix it later .
I hope it passes! V8 or else ...
Post #452234 27th Sep 2017 12:15pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Finally put the lettering on the boot and reattached the strip above the number plate! Smile
Hope the strip stays on, fell off last time Sad
Post #452267 27th Sep 2017 4:23pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Completely emptied the boot and put rear seats down. Headed over to Ripon and picked up four 20 inch rims with tyres. With them and my gardening equipment then headed over to Pickering. Next day off to Hull then back to Merseyside. Wasnt struggling to unload them before running around today as I only got back late and went out early so said tyres got a ride to Birkenhead then up to Preston and back to St Helens. They've done nearly 500 miles and havent touched the floor yet Rolling with laughter
Post #452310 27th Sep 2017 7:46pm
fisha
So. It failed its MOT. One of the bolts holding a rear brake caliper was missing Shocked ... I thought the clicking sound was the pads rattling !!! oops. A mad dash for a spare bolt and its now sorted.
And to add insult to injury today, I tried re-syncing keys to the car. I'm now in a state where one key unlocks, but wont start engine, and the other wont unlock but will start the engine. I need 2 keys to drive my car now!!!!
flippin land rovers.. Rolling Eyes Rolling Eyes Rolling Eyes V8 or else ...
Post #452313 27th Sep 2017 8:29pm
supershuttle
Took off the aero wiper blades and put back the originals, looks better, still thuds when changing direction Very Happy Geoff
Post #452314 27th Sep 2017 8:48pm
DaveK
Old wheels off and new wheels on today. What a bargain for £760 ! Old wheels now washed, wrapped and awaiting collection. They are off to a FFRR owner in Sweden.
Post #452474 29th Sep 2017 6:33pm
gizze
You can buy new clips that hold on the wipers for about £4 each from RR that stops the clunking. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452490 29th Sep 2017 8:44pm
Roadking
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Collected car from being undersealed with Dinitrol. Fitted rear mud flaps. Fitting kit missing from front mudflaps so I think I'll just wash it now.
Post #452525 30th Sep 2017 11:14am
GGDR
Fixed my adaptive dynamics fault. Love a quick fix - all I did was push the grommet back in.
Interestingly, this stops any special programs from working. All good now. Thumbs Up
. Cheers, Greg
Post #452527 30th Sep 2017 11:49am
gizze
I have had a really annoying trim vibration on mine since getting it, it has come from the passenger seat somewhere, if I push the armrest hard it stops, if I push the headrest hard it stops, but no amount of pushing clothes into areas to try and pad it out has stopped the annoying noise over certain surfaces.
Suddenly thought today that maybe it sounded like a spring, I lifted the seat up 1/2" and the noise has gone, it is now nearly a silent cabin! Whooohaa!
I guess the spring has got older and at the lowest setting it is no longer tight enough to not vibrate too much.
So, the only noise left is the slight rear diff whine. Porsche 911 (996)
Post #452530 30th Sep 2017 12:32pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
swapped my bonnet this morning and rectifies the disco going on in the new passenger indicator I fitted yesterday
Post #452549 30th Sep 2017 3:45pm
