Home > Maintenance & Mods (L322) > Brake Tin Rattle Help Please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
if its the bit a think you mean then you need to remove the wheels and tighten..cant remember if its from the rear or behind the brake disc.. |
9th Jan 2011 12:30pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3118 |
this is a great vid on how to change your brakes. It also shows somewhere the brake protector shield which you refer to, so should allow you to access it and tighten up.
9th Jan 2011 1:56pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
Thanks guys!
9th Jan 2011 5:46pm |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
My one corroded through at the fastening points - I also used the tin snips to cut it off - those 16mm carrier bolts where too tight (broke a socket) so I give up - I was going to fit a new spash guard in the warmer weather to - that was a year ago - must do it some day |
9th Jan 2011 8:36pm |
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 |
I had the exact same problem the other day, This can be fixed without removing the brake disc etc. Simply get a large diameter washer for each bolt that the tin splash guard has seperated from. Undo the bolts and redo with the washer in inplace and tighten. Its a tight finger sqeeze to do,but saves so much time.
10th Jan 2011 12:38am |
You have to remove the hub assembly to replace the back plates, easier said then done.
12th Jan 2011 2:38pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
for those that don't know, never ever weld (especially arc weld) on a vehicle without disconnecting the battery and or alternator - otherwise it is more than likely you will blow it or both. |
12th Jan 2011 6:05pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
And don't forget to have a fire extinguisher to hand, ask me how I know this.......... |
13th Jan 2011 9:54am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
How do you know this Richcl? Ian |
13th Jan 2011 12:24pm |
Um ....Discovery (Mine luckily!) welding rear sill.....could see flames behind patch I was welding, thought I'll just blow that out (probably fed the flames! ) Anyway, flames don't go away, so open door to see flames up the side trim and headlining!
13th Jan 2011 12:42pm |
kineavy Member Since: 21 Dec 2015 Location: Cambridge Posts: 33 |
Noticed this on my FF yesterday and I think I will go down the tin snips route. Just going to go Screwfix this morning to invest in one.
8th May 2016 8:43am |
