Home > Maintenance & Mods (L322) > Brake Tin Rattle Help Please
Reformed
Whilst driving the car back home last night I noticed a tinny rattle coming from the front.
After crawling under it this morning, I noticed that the tin plate that sits behind the front discs is quite loose (When I move it around thats the noise I was hearing).
The passenger side is tight, but for the life of me I cant see anyway of tightening it up?
Anyone had this, or now how to tighten it back up?.
At least I can live with the rattle now I know what it is tho! Laughing Reformed
Post #45217 9th Jan 2011 10:44am
if its the bit a think you mean then you need to remove the wheels and tighten..cant remember if its from the rear or behind the brake disc..
Post #45219 9th Jan 2011 11:30am
Dolphinboy
this is a great vid on how to change your brakes. It also shows somewhere the brake protector shield which you refer to, so should allow you to access it and tighten up.
Post #45223 9th Jan 2011 12:56pm
Reformed
Thanks guys!
Problem sorted! I removed the wheel and there are some small bolts that hold it in place, but it has broken from all of them so there was no way of tightning it Big Cry
As the rattle was annoying, my trusty tin snips and I have removed it! Whistle
I will replace both sides with new ones later this year when the weather is warmer as I plan on changing my discs and pads anyway. Alltho the other side is tight I might as well do them both together. Reformed
Post #45238 9th Jan 2011 4:46pm
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
My one corroded through at the fastening points - I also used the tin snips to cut it off - those 16mm carrier bolts where too tight (broke a socket) so I give up - I was going to fit a new spash guard in the warmer weather to - that was a year ago - must do it some day Whistle
Post #45257 9th Jan 2011 7:36pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
I had the exact same problem the other day, This can be fixed without removing the brake disc etc. Simply get a large diameter washer for each bolt that the tin splash guard has seperated from. Undo the bolts and redo with the washer in inplace and tighten. Its a tight finger sqeeze to do,but saves so much time.
Fraser
Post #45325 9th Jan 2011 11:38pm
You have to remove the hub assembly to replace the back plates, easier said then done.
My suggestion is to cut the new plates with a hacksaw, slip them on and then put a small weld on the cut to hold it in place
Post #45737 12th Jan 2011 1:38pm
Vogue
for those that don't know, never ever weld (especially arc weld) on a vehicle without disconnecting the battery and or alternator - otherwise it is more than likely you will blow it or both.
Post #45789 12th Jan 2011 5:05pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
And don't forget to have a fire extinguisher to hand, ask me how I know this.......... Big Cry
Post #45855 13th Jan 2011 8:54am
T24RES
How do you know this Richcl? Rolling with laughter Ian
Post #45866 13th Jan 2011 11:24am
Richcl
Um Embarassed ....Discovery (Mine luckily!) welding rear sill.....could see flames behind patch I was welding, thought I'll just blow that out (probably fed the flames! Laughing ) Anyway, flames don't go away, so open door to see flames up the side trim and headlining! Shocked
Luckily I had extinguisher! Phew!
(£200 worth of secondhand parts later, Discovery was back to normal. Driving around with burnt out (smelly) interior was a new experiance! )
Post #45868 13th Jan 2011 11:42am
kineavy
Noticed this on my FF yesterday and I think I will go down the tin snips route. Just going to go Screwfix this morning to invest in one.
Do I need to remove the wheel if I am just cutting the guard off or can to be done with the wheel on?
Post #385876 8th May 2016 7:43am
