Home > Maintenance & Mods (L322) > Sagging seat??
Sandyt
Sagging seat??
Gents I have a sagging seat (I know Iknow) anyway have a man coming to re colour and also do door card repairs where the doors have been shut with the seat belt in situ I am wondering if it is worth replacing the squab - its only 85 quid from Dan or will the leather still look loose ? the rest of the seats are all in good nick as very rarely used
Post #449416 29th Aug 2017 10:00am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
It would only look vastly different if the seat base foam has collapsed. If not, might be worth getting someone to take the base cover of and refit it and repair it if necessary.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #449423 29th Aug 2017 12:02pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
im hoping to do the same , im only slim and really notice the lack of support from that part of the seat
Post #449426 29th Aug 2017 1:00pm
CS
I recall reading that the seat bases are the same right and left, so perhaps swap the worn driver seat base for the passenger one? That said on my P38 the seat base foam was replaced (under warranty, the seat had been misbuilt with a fold in the foam near the outer edge) and that seemed easy enough for the dealer to do, so perhaps easy and not too expensive on the 322 also. Only Range Rovers since 1988
Post #449438 29th Aug 2017 2:26pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi , would anyone have a part number for the seat foam for a 2007 VSE 3.6 please ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449454 29th Aug 2017 5:05pm
Sandyt
Send Dan at Duckworths your Vin and he will give you the part number and a quote
Post #449462 29th Aug 2017 6:52pm
Sandyt
I took the p38 seats apart to repair the heated element in the seat its not a difficult job on these either just the hog rings and on the p38 I binned them and used cable ties - that was 10 years ago and still have the p38 and its still good
Post #449463 29th Aug 2017 6:54pm
dolph34
Thank you 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449466 29th Aug 2017 7:12pm
dan_uk_1984
I replaced my seat base, was fiddly but not too difficult. It must be done out of the car and an extra pair of hands really is needed as you need someone to steady the seat as you apply pressure here and there. The old one is easy to get out, but the leather is much tighter going over the new foam obviously.
You will need to buy hog ring pliers and some new hog rings and you'll need a decent pair of snips to cut the old rings. I think I paid �70 from Dan @ Duckworth last year according to my records.
So glad I did it, after 185k - it feels like you're sitting in a new car.
D
Post #449499 30th Aug 2017 9:07am
bembo449
im just waiting for a price from dan
Post #449521 30th Aug 2017 1:29pm
Sandyt
Thanks Dan has to be done Thumbs Up
Post #449615 31st Aug 2017 1:43pm
Sandyt
Unnecessary quote removed
Dan is there a retaining stitch running side to side across the middle that you have to pick up or does the leather just sit straight over the base ?
Post #449619 31st Aug 2017 1:58pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I've done a few of these and as Dan Uk 1984 says, once the seat is out of the vehicle (necessary, remember to disconnect the battery first before unplugging the various electrical connectors, else you'll trigger the airbag warning and need an iid or similar to reset and only connect the battery again once everythings back in place) so long as you're methodical, it's not too challenging. Metal snips (to cut the existing hog rings securing the leather cover to the seat foam) and hog ring pliers (to re-attach) are needed, not too difficult once you get the hang of it. Some use plastic tie wraps instead, but I personally wouldn't.
No stitching to undo / re-stitch.
Give it a go!
Post #449634 31st Aug 2017 4:53pm
bembo449
my base foam is on its way , ive done this sort of thing a few times on other cars , tip about the battery is most appreciated , wouldn't be an issue on most other cars
Post #449743 2nd Sep 2017 8:58am
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Hog rings are cheap and can be fitted with ordinary pliers, fiddly but do-able.
Post #449768 2nd Sep 2017 3:35pm
