Home > Maintenance & Mods (L322) > Sagging seat??
gizze
Also, if the leather itself is stretched you need to put some heat on it, very good hairdryer that goes hot or a heat gun will get it almost as tight as new, but if you can get your hands on a steamer that is even better.
Do it before it is resprayed. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #449777 2nd Sep 2017 5:55pm
GGDR
bembo449 wrote:
my base foam is on its way , ive done this sort of thing a few times on other cars , tip about the battery is most appreciated , wouldn't be an issue on most other cars
How much was the base foam bembo?
. Cheers, Greg
Post #449781 2nd Sep 2017 6:34pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
just over 70 quid pal
Post #449984 5th Sep 2017 7:19pm
bembo449
fitted my new seat this aft , what a difference it makes , well worth the expense and time , so if your driver seat is in poor health , think about a new foam , you wont regret it
simon
Post #450280 8th Sep 2017 4:36pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Done several D1 seats, makes a big big difference, more so than you would think. Thumbs Up
Post #450296 8th Sep 2017 6:15pm
GGDR
Unnecessary quote removed
Sounds great, how long does it take Simon?
. Cheers, Greg
Post #450317 8th Sep 2017 8:56pm
bembo449
believe me pal , it is great , depends on your mechanical skills really pal , if your a competent DIYer then 2 1/2 hours ish , don't really need much kit to do it either , think there is a bit in wiki on doing the job Wink
Post #450318 8th Sep 2017 9:01pm
GGDR
Simon just resurrecting this this thread - when you changed your seat foam, did you need to take the seat out?
Cheers,
Greg Cheers, Greg
Post #475860 14th Apr 2018 11:30pm
GGDR
Does anyone else know if I need to remove the whole seat to get the leather cover off?
Want to replace the seat base cushion.
Cheers, Greg
. Cheers, Greg
Post #475878 15th Apr 2018 9:00am
