![]() | Home > Maintenance & Mods (L322) > Sagging seat?? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Gents I have a sagging seat (I know Iknow) anyway have a man coming to re colour and also do door card repairs where the doors have been shut with the seat belt in situ I am wondering if it is worth replacing the squab - its only 85 quid from Dan or will the leather still look loose ? the rest of the seats are all in good nick as very rarely used
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
It would only look vastly different if the seat base foam has collapsed. If not, might be worth getting someone to take the base cover of and refit it and repair it if necessary.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
im hoping to do the same , im only slim and really notice the lack of support from that part of the seat |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi , would anyone have a part number for the seat foam for a 2007 VSE 3.6 please ? 2015 4.4 AB
Send Dan at Duckworths your Vin and he will give you the part number and a quote |
I took the p38 seats apart to repair the heated element in the seat its not a difficult job on these either just the hog rings and on the p38 I binned them and used cable ties - that was 10 years ago and still have the p38 and its still good |
Thank you 2015 4.4 AB
I replaced my seat base, was fiddly but not too difficult. It must be done out of the car and an extra pair of hands really is needed as you need someone to steady the seat as you apply pressure here and there. The old one is easy to get out, but the leather is much tighter going over the new foam obviously.
im just waiting for a price from dan |
Thanks Dan has to be done |
Unnecessary quote removed
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 903 ![]() ![]() ![]() |
I've done a few of these and as Dan Uk 1984 says, once the seat is out of the vehicle (necessary, remember to disconnect the battery first before unplugging the various electrical connectors, else you'll trigger the airbag warning and need an iid or similar to reset and only connect the battery again once everythings back in place) so long as you're methodical, it's not too challenging. Metal snips (to cut the existing hog rings securing the leather cover to the seat foam) and hog ring pliers (to re-attach) are needed, not too difficult once you get the hang of it. Some use plastic tie wraps instead, but I personally wouldn't.
my base foam is on its way , ive done this sort of thing a few times on other cars , tip about the battery is most appreciated , wouldn't be an issue on most other cars |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Hog rings are cheap and can be fitted with ordinary pliers, fiddly but do-able. |
