![]() | Home > Maintenance & Mods (L322) > Urgent A post photo required 2011 MY |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Wife is just putting tea on the table Adrian, but will do in half an hour . G reg 2.5VM Vogue Portofino red 1991- 1999
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
The flappy bit at the end is attached to the roof finisher trim and literally just sits there.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
pics sorted mike.. |
Thanks Stan, you really need to give me lesson in picture posting.
....or this which is much easier, turn the camera!!! ... - .- -.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I had a similar problem with auto glass a few years ago and they took it in and replaced the windscreen yours has been fitted wrong when they are fitted correct the trims all fit flush also they should have used new trim not the old one as it gets twisted when they take it off hope that helps |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Would hazard a guess it's a couple of mm to high. Would take a pic of mine, but I'm away, so can't. In any case never been a really good fit! There is nothing that can't be fixed with a hammer😜😜
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
Many many thanks folks. This is very much appreciated and reinforces my concerns.
Make sure your roof trim is pressed down securely,The flappy bits in the corners are fixed to that.
Thanks again.
