Home > Maintenance & Mods (L322) > Urgent A post photo required 2011 MY
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi
Just had National Windscreen replace the front and all looked ok. My Son came home (techie apprentice) and took one look at the top of the A posts and pointed out the lack of seal or cover etc.
when the screen fitters told me they had 'finished' there was a gap between the screen base and scuttle trim which I was not happy about so this took over the conversation. I did not spot the error at the top corner. (bit embarrassed about that)
Can anyone take a photo of a factory finished Top of A post to screen junction for me please? NW are supposed to be sending someone out tomorrow and I want to have some ammo in my back pocket.
This is how it was left.... The top roof strip appears quite loose on each side too.
Thanks in advance.... Thumbs Up
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #448054 16th Aug 2017 4:56pm
Baltic Blue
Wife is just putting tea on the table Adrian, but will do in half an hour . G reg 2.5VM Vogue Portofino red 1991- 1999
Post #448055 16th Aug 2017 5:08pm
Crispian22
This is how mine is finished.
07 year.
Post #448057 16th Aug 2017 5:33pm
Crispian22
The flappy bit at the end is attached to the roof finisher trim and literally just sits there.
Had a look at some spare trims I have and there the same as what's on my car already.
Post #448058 16th Aug 2017 5:35pm
Baltic Blue
Sorry if they appear wrong way up ??
Stan once again sorry.
I have no reason to think my screen has ever been replaced, but now I have given it close inspection the finish is not brilliant in the corners. ( Touch wood it has never leaked ).
Post #448059 16th Aug 2017 5:37pm
pics sorted mike.. Thumbs Up ... - .- -.
Post #448066 16th Aug 2017 7:09pm
Baltic Blue
Thanks Stan, you really need to give me lesson in picture posting.
My best average is 50% .
Either that or I will lay my car on its side next time 😁😁. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #448072 16th Aug 2017 7:51pm
....or this which is much easier, turn the camera!!! ... - .- -.
Post #448073 16th Aug 2017 8:00pm
Sandyt
I had a similar problem with auto glass a few years ago and they took it in and replaced the windscreen yours has been fitted wrong when they are fitted correct the trims all fit flush also they should have used new trim not the old one as it gets twisted when they take it off hope that helps
Post #448076 16th Aug 2017 8:12pm
Would hazard a guess it's a couple of mm to high. Would take a pic of mine, but I'm away, so can't. In any case never been a really good fit! There is nothing that can't be fixed with a hammer😜😜
Post #448077 16th Aug 2017 8:16pm
ajac8
Many many thanks folks. This is very much appreciated and reinforces my concerns.
Thanks again.
I'll post the outcome for reference. - I think a lot of insurance firms use National Windscreens.
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #448080 16th Aug 2017 10:20pm
Crispian22
Make sure your roof trim is pressed down securely,The flappy bits in the corners are fixed to that.
Having removed some from a scrapper recently,they seem to just push down on the screen with the force of the fitting in the roof gutter.
They may have dislodged it whilst fitting.
Post #448081 16th Aug 2017 10:29pm
Crispian22
Post #448082 16th Aug 2017 10:32pm
ajac8
Thanks again.
I have to say notwithstanding the fact they made the error in the first place, National Windscreens have made good. By 9am this morning they had rung me back and by 12:00pm it was all fixed.
The front flappy rubber 'square' has been relocated both sides and further secured with non-setting adhesive putty (in case the screen needs to ever come out again)
no more wind noise and much more confidence with the replacement screen.
Thank again for all the help. Thumbs Up
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #448150 17th Aug 2017 4:20pm
