Home > Technical (L322) > Anyone put hybrid turbos on a tdv8 ? |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Never heard of anyone using another turbo. I can't see that fitting different turbos would be easy given they operate by an electronic actuator. ______________________________
28th Jul 2017 7:57pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Had mine replaced recently and was very surprised how small they are. Would need a remap to cope with extra air and maybe larger injectors. 2015 4.4 AB
28th Jul 2017 8:32pm |
Yes the look fairly small, but I suppose there's two of them and each bank is only 1800cc.
29th Jul 2017 3:03am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Hybrid turbos aren't some magic performance part, they're just turbos assembled with a non-standard cold or hot side - not sure it's really a valid term nowadays, when you can buy one with pretty much whatever spec you want. |
29th Jul 2017 11:53am |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 |
So would a modified compressor in the turbo not improve the performance ? |
29th Jul 2017 4:47pm |
Ive had cosworths and Subarus with Hybred turbos over the years and they all required larger injectors, bigger intercoolers, different ecus, etc. I dont think just modifying a turbo with a larger compressor wheel , etc would be effective becuase the standard ECUmight not have the parameters to deal with more airflow and provide enough fuel to match the increased airfllow.
29th Jul 2017 9:02pm |
