Home > Technical (L322) > Power Steering failure on holiday...heeellppp
n1cktdv8
2008 Range Rover Vogue TDV8 Stornoway Grey
So I had a 1069 mile drive and she didnt miss a beat...all the way through France and into Spain.
I pull up on the campsite, got tintent into place and suddenly no power steering. She dumped all the fluid whilst static. I had been lock to lock getting on this pitch but it never once felt stiff.
Not driven it since. I have euro cover so no probs there but wonder if its easy to access the hoses for a quick inspection.
Cheers folks Is this where I put the car details and a bit about myself ?........
Post #446224 31st Jul 2017 5:29am
Clivefog
United Kingdom 2003 Range Rover Vogue 4.4 V8 Java Black
Find the reservoir check hoses are attached. Follow the hoses down and see where you can see wetness/fluid. No obvious leak will mean it is at the rack or pump, may be hose come off rack or pump. Unlikely to be pump seals but may be rack seals if held on full lock?
Best of luck and enjoy the holiday.
Post #446229 31st Jul 2017 6:52am
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
n1cktdv8, the reservoir you can pull up and out so to make inspection easier, it just slides in and out the holder.
good luck
Post #446230 31st Jul 2017 7:31am
with all that lock to lock i'd punt for a hose coming off hence the large fluid loss.. ... - .- -.
Post #446232 31st Jul 2017 8:20am
