Home > Technical (L322) > Anyone put hybrid turbos on a tdv8 ?
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Was thinking about the amount of tdv8 with turbo issues , has anyone put uprated turbos on one ?
I would imagine it would go quite well.
Post #446059 28th Jul 2017 7:48pm
rar110
Never heard of anyone using another turbo. I can't see that fitting different turbos would be easy given they operate by an electronic actuator. ______________________________
Post #446060 28th Jul 2017 7:57pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Had mine replaced recently and was very surprised how small they are. Would need a remap to cope with extra air and maybe larger injectors. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #446068 28th Jul 2017 8:32pm
rar110
Yes the look fairly small, but I suppose there's two of them and each bank is only 1800cc.
I remember thinking the 300tdi turbos were also quite small when I had a look at one. ______________________________
Post #446085 29th Jul 2017 3:03am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Hybrid turbos aren't some magic performance part, they're just turbos assembled with a non-standard cold or hot side - not sure it's really a valid term nowadays, when you can buy one with pretty much whatever spec you want.
Post #446108 29th Jul 2017 11:53am
Gumball3000
So would a modified compressor in the turbo not improve the performance ?
Post #446136 29th Jul 2017 4:47pm
dolph34
Ive had cosworths and Subarus with Hybred turbos over the years and they all required larger injectors, bigger intercoolers, different ecus, etc. I dont think just modifying a turbo with a larger compressor wheel , etc would be effective becuase the standard ECUmight not have the parameters to deal with more airflow and provide enough fuel to match the increased airfllow.
Have you tried a remap ? I think they take the standard parameters to the max or close enough that your not stressing the engine components unduly.
Im very far from an expert so the above is my limited knowledge. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #446151 29th Jul 2017 9:02pm
