Home > Technical (L322) > 4.4 TDV8 MAP sensor
Page 5 of 10 <12345678910>
Baltic Blue
I think I agree Nino-Nino.
I took mine over Holme Moss earlier (1 in 6 climb used when Tour de France came to UK ).
I deliberately approached it fairly slow then flooded it in D ,
I had to ease off on 2 of the bends but I was low flying when I went over the summit. 😁😁😁 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443702 6th Jul 2017 11:10am
stu
Can I just ask what is the 80mph software update?
Nino, I'm afraid no Hekwap for you this time as the battery disconnect didn't work, it is a split hose. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443705 6th Jul 2017 11:41am
Baltic Blue
Stu,
You will have earned a pint of lager when you have cleaned it all up, re-assembled, and cleaned your hands.
Glad it turned out to be an easy fix, but I am sure we have all learned from it.
The 80 mph software update is detailed in LTB 00454 v2 , sorry I have not got a copy to post but it details the cure for a slight misfire which occurs between 75 - 80 mph.
Mine had always done it ( I would describe it as a cough - hiccups) but it is silky smooth since having it done on Monday.
Stan may have a copy of the bulletin?
Cheers
Mike.
I am thinking of paying a days subscription to Topix to download the LTB's in the same way I did with the WM, but it will have to wait until after my holidays. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443708 6th Jul 2017 12:02pm
stu
Mike, is this something you have to pay for? I should know better than to ask questions like that in the same breath as JLR matters, but hey hoe? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443710 6th Jul 2017 12:16pm
Baltic Blue
I was very lucky they didn't charge me to do it, but included it as part of the full annual service and MOT which was free because it was part of the original purchase deal.
I will be getting my hands dirty doing my own service next year because my warranty deal has now expired.
Cheers
Post #443715 6th Jul 2017 1:06pm
i cant find the actual tsb pdf document but it was discussed here,
http://www.fullfatrr.com/forum/topic38291....ltb00454v2 ... - .- -.
Post #443720 6th Jul 2017 1:31pm
Baltic Blue
Stan,
If I save up my pocket money and invest in 24hour Topix subscription to download all the TSB's as pdf's, are you happy to host them on the same terms as the Workshop Manual ?
Cheers & I enjoyed seeing your holiday photos.
Post #443729 6th Jul 2017 1:52pm
honoured to do that Mike, and thanks. ... - .- -.
Post #443733 6th Jul 2017 2:05pm
Baltic Blue
I have got a couple of mini holidays booked to enjoy B.B. whilst it is firing on all cylinders, but I will sort it first free rainy day.
Cheers
Post #443736 6th Jul 2017 2:31pm
nino_nino
Mike, I'll be happy to contribute for that. Thumbs Up
Post #443738 6th Jul 2017 3:03pm
Baltic Blue
Kind offer Nino but you had better save your Euros to buy Stu his lager😁😁👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443750 6th Jul 2017 6:06pm
nino_nino
stu, how much is the lager in your watering hole? I'll use PayPal Thumbs Up
Post #443759 6th Jul 2017 7:29pm
stu
Laughing just send me some Hekwap... Thumbs Up even with postage it'll be cheaper than buying one here! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443765 6th Jul 2017 7:47pm
Baltic Blue
Have you done a good test run Stu ?
Hope all is well now.
Post #443766 6th Jul 2017 8:03pm
stu
Not back together yet, doing it tomorrow! Will confirm all is good then. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443769 6th Jul 2017 8:13pm
