![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2580 ![]() ![]() ![]() |
I blocked EGR but for only a very short time because of severe driveability issues. Next time I'll try removing the throttle butterfly at the same time. I considered that the butterfly was being closed attempting to increase EGR because the MAP sensor probably showed excessive airflow. The lack of fault codes indicates it's worth a 2nd try. |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Thanks Graeme,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it looks scary
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Here's what my MAP sensor looks like on the 3.6 TDV8. After 265,000 km it's not too bad. But I have disabled the EGRs and put a couple of doses of induction cleaner through which probably made a difference. I checked the MAFs last night, and both were pretty clean.
Nino-Nino,
I should add the 3.6 has two MAP sensors. They looked the same.
There was a bit of grime on the MAFs but not too bad. ______________________________
rar110 at least your intake is dry,maybe indicating what rubbish is seen is what stayed behind when the cleaner was put trough.The other example looks like exhaust rubbish and is very clogged!!
Here's another pic. It was oily under the surface.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
reading this thread with interest...so where in the engine bay is this notorious map sensor.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
thanks mike but i meant sort of where in the engine bay... |
yes i did clean throttle body and plastic air plenum. My car was at 85K km when the picture was taken and i am at 156K km now, so time for another cleaning job.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
I did a cleanup when I was replacing the oil cooler gaskets like Nino.
