Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground
Page 3 of 5 <12345>
miggit
the trouble with lifting on the arm is that they are not parallel to the ground so you can't get a firm place to jack from, this is further compounded by the suspension dropping as the car is lifted... It is normally ok with a professional standard jack, especially if it has a rubber cup pad, as they tend to be 4-5 " in diameter and will still give support if there is some movement. Yesterday I couldn't spell Engineer... Today I are one!
Post #441941 18th Jun 2017 10:21pm
Les_Paul
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
miggit wrote:
Les_Paul wrote:
How about this jack? Just keeping it in the truck won't harm the longevity of the jack?
Pro-Lift B-006D Grey Hydraulic Bottle Jack - 6 Ton Capacity https://www.amazon.com/dp/B00DGXVX18/ref=c...rzbQK9KB2N
NOPE!! it's a single stage lift, the Mercedes Sprinter jacks are telescopic 2 stage, which gives them almost twice the lift of a standard bottle jack.
The 2 stage lift doesn't make sense to me. What is the difference of having a manual screw-top to get the jack to touch the jack point and having a jack that has more hydraulic travel? Shouldn't 8" of hydraulic lift be plenty to raise a wheel off the road?
Post #442058 20th Jun 2017 2:01am
Baltic Blue
I changed all 4 wheels on mine yesterday using my modified Sprinter jack.
It was half-way up the second piston before the wheel was off the ground .
Combined with the wheel fitting guides bought from here on the forum , job completed in a couple of hours.
2 excellent pieces of kit, well worth investing in. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #442069 20th Jun 2017 8:49am
nino_nino
miggit is right, the arm is not parallel to the ground, but only in the off road height. however , arm has saddle like part where our "Mighty Jack" fits rather nicely. the pictures are taken with the car in normal height.
and because we are lifting the wheel and not the car suspension will not drop, . if one had 4 jacks like this you could lift all 4 wheels and ECU would not know the car is off the ground.
I was able to lift the wheel 1 1/4" with only first stage of the jack.
and here is pic, with wheel off
in the back there is nice spot for the jack too
this is with car in off road height
and here it is British engineered "Italian Job"
I love well made piece of equipment. Smile
Post #442092 20th Jun 2017 2:04pm
^ great informative post Thumbs Up Thumbs Up ... - .- -.
Post #442096 20th Jun 2017 3:05pm
Tommy62
Norway 2007 Range Rover Vogue SE TDV8 Java Black
Hi, Im a new member here and I am thankful for a great forum for my Rangies. I have L 322 TDV8 self and I by a jack adapter from my Norvegian forum NLRF or LR forum.com. The adapter are developed and produced by our moderator. The adapter changes out with the orginal top foundation on the MB sprinter or WV Crafter jack. Thise adapter was produced on a mechanical school and wil fit perfect attached to the body guard underneath the car.
Post #442586 24th Jun 2017 5:47pm
someone on this forum also produced an adapter, cant think who it was now.. ... - .- -.
Post #442590 24th Jun 2017 6:27pm
Baltic Blue
This link shows pictures of the one I made.
http://www.fullfatrr.com/forum/topic40554.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #442600 24th Jun 2017 8:42pm
Just modded my sprinter Jack this weekend.
For info it does fit under the car with steps extended and locked.
 There is nothing that can't be fixed with a hammer😜😜
Post #477764 8th May 2018 5:41pm
Baltic Blue
Changed all 4 wheels again this weekend using “sprinter”.
The jack fits into the jacking point, front or back, with car at normal ride height and is half way up second piston when wheels clear of ground.
Post #477765 8th May 2018 6:04pm
Triumph69
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi this is exactly what I would like to do
Post #488133 6th Sep 2018 1:08pm
Triumph69
This is exactly
Mike.
Post #488134 6th Sep 2018 1:08pm
Triumph69
Struggling to find the adaptor and exact jack any ideas welcome
Post #488136 6th Sep 2018 1:10pm
nino_nino
My primary jack is two stage Disco jack. that is in the car all time. my second jack is generic 3T one stage jack with modified head, so it fits in the reces on the car. with piece of 2x6 undernneath it will lift the wheel of the ground cc-1 1/2".
Nino, Thumbs Up
, 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #488155 6th Sep 2018 4:31pm
Baltic Blue
You could try a wanted ad on here.
I may have dreamt it, but I think someone posted that the sprinter is Not usable on the L405, so someone who has traded up may have one to sell ?
Post #488156 6th Sep 2018 4:38pm
Page 3 of 5 <12345>
