Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Hi all,
7th May 2017 12:34pm |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
most people here use the MB sprinter van bottle jack plenty on ebay or search on here jack |
7th May 2017 12:45pm |
http://www.fullfatrr.com/forum/topic40554.html?highlight=jack |
7th May 2017 12:48pm |
thats what i am looking for
7th May 2017 12:50pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Next to the spare wheel there's a rubber holder that holds the jack. I've managed to get mine to hold my bottle jack in situ.. as long as you mind and rotate the jack every now and again it's fine |
7th May 2017 4:16pm |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
Ah, should the original be horizontal, in front of the spare wheel ? Would it have been a scissor jack. Noticed an empty "gap" but it's not very high. Thinking about it, looks scissor jack shape. |
7th May 2017 4:36pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Yes original is scissor jack in straps in front of the spare wheel. (behind it looking from the back). It was/is a dangerous load of carp. John
7th May 2017 4:38pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
I'm going to get a Merc bottle jack. I don't trust the scissor jack that's supplied and my 3 tonne trolley was bought purely fo the FFRR, and I leave that at home !! Is this where I put the car details and a bit about myself ?........ |
7th May 2017 4:48pm |
Thanks |
7th May 2017 5:10pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Why do 3 ton trolley jack weigh 3 tons I've got a 2.5 ton Ally / steel hybrid jack... a lot lighter than an all steel construction jobby... But for emergancy use only then a Mercedes Sprinter bottle jack is the way to go!! Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
8th May 2017 11:59am |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 |
In emergency I like a jack from the AA especially on the hard shoulder
8th May 2017 12:12pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Merc sprinter as mentioned and an Iveco Daily jack will do the job. |
10th May 2017 1:19pm |
naks Member Since: 28 Sep 2016 Location: Stellenbosch Posts: 26 |
When I bought my D4, I simply got a decent 3t bottle jack, and got a solid, square piece of wood to use as a base plate Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
10th May 2017 1:49pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
A lot of 3-5 ton bottle jacks are only single piston lift, which is not sufficient to cope with the suspension travel, so you really need to be looking for a 3 ton + jack with a double lift even if you stand it on a block of wood you still have to allow for the amount of suspension travel. G reg 2.5VM Vogue Portofino red 1991- 1999
10th May 2017 4:26pm |
