Home > Technical (L322) > Air Bag Light!
RRR207
Switzerland 2005 Range Rover Autobiography 4.4 V8 Zambezi Silver
Air Bag Light!
My airbag light has just pinged up & stayed on Big Cry
I've just had the external door release cable replaced on the drivers door .... is there a possible link here or is it pure coincidence?
I assume getting it on a diagnostic/IID tool is the first option and see what comes up? Current - RRV Autobiography 4.4V8 2005
Modifications - 20" Westminster Alloys with Grabber AT's. BRC LPG Conversion.
Previous- RRC 3.9V8/91. RRC 4.2V8/94 LSE Softdash. RRC 2.5tdi/94. RRC 2.5tdi/91. RR p38 2.5DHSE/01, Disco2 2.5td5/03, Disco4 2.7tdv6/10 ..... all gone.
Member of the RangeRoverRegister & Wessex4x4Response (Bristol Team)
Post #441063 9th Jun 2017 1:18pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
There's an airbag in the door so it's probably linked, might have disturbed something when the cable was fitted.
Take it back to whom ever fitted it and get them to take a look, might just be a loose connection.
Post #441064 9th Jun 2017 1:22pm
loads of connections behind the door card, as suggested one might be loose or not connected.. ... - .- -.
Post #441068 9th Jun 2017 2:18pm
rar110
The red airbag light also relates to seatbelt pretensioners. I had a loose wire under the driver seat. The IID tool picked it up. I just had to fiddle with the position of the wire and it was fixed. ______________________________
Post #441110 9th Jun 2017 8:41pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
And also the battery disconnect (yellow connector). I need to wiggle mine occasionally as it seems to develop a high resistance every once in a while... Must remember to take it apart properly next time the battery is disconnected.
Post #441165 10th Jun 2017 6:51pm
