Home > Technical (L322) > Error codes help
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Error codes help
Been having some issues recently after the mot and the car going into transport mode.
Local garage ran a diagnostic last week, this is after the main dealer looking at it, charging us £400 and finding nothing, we now have.
P1614 electric thermostat circuit open. Drive cycle A
U0121 lost comms with anti lock brake system control moduke
Abs supply faukt
Abs ecu fault
Can bus fault.
Its going back to the main dealer next week following a complaint to them, I'm away from home but does the above sound expensive?
I have a feeling battery could be at fault as it was disconnected for a couple of days during the mot as we were waiting for a new airbag and door lock to arrive.
Post #441143 10th Jun 2017 1:33pm
kbald
Have they cleared the codes then run the scan again to see what is current? lots of codes come up are historical and mean nothing and there are always communication faults showing despite things working correctly.
What issues are you having that are causing you to have the codes read? A low battery will throw up faults that aren't really there so you could do with having it fully charged when reading the codes. Current 2007 TDV8 Vogue Buckingham Blue
Post #441152 10th Jun 2017 2:32pm
