![]() | Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
do you think a td5 disco bottle jack would do ? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I am using one with a piece of 4"X6" under for added height |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
naks Member Since: 28 Sep 2016 Location: Stellenbosch Posts: 26 ![]() ![]() |
even if you jack it up under the suspension arm?
That's not the safest option, it only takes the suspension to have one of it's little paddies and it'll pop off the jack.... if you use a high lift (2 stage ) bottle jack in the jacking positions on the sill it is held in place... I'd only use my trolley jack to raise a ffrr at that point cos the cup is 100mm dia and it also has a rubber insert for added grip |
perfect will put in car. have only jacked up car with trolley jack about 100 times at least. don't want caught out although I am with the AA I never needed them for flat (yet) especially with lpg so room for spare is not possible . |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Ebay seller would not accept £30 offer, almost instant decline, did accept £33.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
dispense with blocks of wood, spacer etc and just get this and have plenty of lift.
Les_Paul Member Since: 14 Jun 2017 Location: Houston, TX Posts: 9 ![]() ![]() ![]() |
How about this jack? Just keeping it in the truck won't harm the longevity of the jack?
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
@nino.
NOPE!! it's a single stage lift, the Mercedes Sprinter jacks are telescopic 2 stage, which gives them almost twice the lift of a standard bottle jack. Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Gyre8,
Ah. Thanks, Nino. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Any reason why lifting from the suspension arm is not recommended?
