Home > Technical (L322) > Sealant or no sealent
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I'm about to service my gearbox due to the gasket on the sump failing.
My question is do I use sealant on the new gasket and if yes what's best to use?
Post #437206 5th May 2017 9:16pm
Rangeyman
I always struggle to believe a dry hard paper gasket will seal so I always use a little selant,i use 'blue hoylemor' or 'haemetite'[am sure I have spelt both them wrong],just a faint smear to both sides making sure you get no lumps on the oil side,not had a problem !
Post #437208 5th May 2017 9:56pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Make sure the sump sealing surface is flat. I had to redo is as the returning company the PO used overtightened the bolts and crushed the gasket.
Post #437702 9th May 2017 6:28pm
