![]() | Home > Technical (L322) > Sealant or no sealent |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I always struggle to believe a dry hard paper gasket will seal so I always use a little selant,i use 'blue hoylemor' or 'haemetite'[am sure I have spelt both them wrong],just a faint smear to both sides making sure you get no lumps on the oil side,not had a problem ! |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Make sure the sump sealing surface is flat. I had to redo is as the returning company the PO used overtightened the bolts and crushed the gasket. |
