![]() | Home > Technical (L322) > Steering wheel auto raise & lower |
I presume yours is a facelift tft car? If so, turn off easy entry in the vehicle settings on the dash screen/vehicle setup screen |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 ![]() ![]() ![]() |
No mine is January 2009 so not that model so I don't have that option, is there another way to do it? |
D34NO Member Since: 21 Jul 2016 Location: Lincoln Posts: 46 ![]() ![]() ![]() |
Hi i just noticed this topic and similar was happening to me but my seat was moving as well, every time i got out id come back to a different driving position, then one day i realised it was my fat arse hitting the memory buttons on the side of the seats (the plastic bit was broke and bending down and pressing buttons) |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Not sure I would have volunteered that information |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
My bad lol my arse isnt actually that fat its just as i get out and off the chair the broken plastic trim was hitting the buttons below and adjusting ......ill shut up lol |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
Just as an aside, my wheels in/out and memory has just started working again after not working at all since i got it. The up down tilt worked but never actually did anything unless I pressed the lever, and now for no reason at all the entire thing moves back and up when I turn off the ignition and comes back to my driving position when I switch on again |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 251 ![]() ![]() ![]() |
So is there a way to disable the function in a pre-tft car? 12 4.4 TDV8 Vogue
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
the GAP iidtool will disable it.. ... - .- -.
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
I found it best to disable this function with IID. The motor going in/out/up/down everytime you get in and out seemed to |
agreed, i've done this with all my FF's..the whirring motor sound is a bit off putting, maybe if it was silent it wouldn't be so bad.. ... - .- -.
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
I see this thread is a few years old but my '09 is also doing this.
winaje Member Since: 05 May 2019 Location: Nth GA Posts: 3 ![]() ![]() ![]() |
Holy thread Necro Batman... I know, I'm sorry... Can someone please tell me the exact IID CCF setting to disable this auto movement everytime you turn the key on and off? Thanks |
