Home > Technical (L322) > Steering wheel auto raise & lower
peejay
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Craig, I'm a skinny old Brit so not bothered if I don't have the function........so how do I turn it off in the dash? Can I do it without an iiD tool?
Post #392414 20th Jun 2016 9:02pm
I presume yours is a facelift tft car? If so, turn off easy entry in the vehicle settings on the dash screen/vehicle setup screen Thumbs Up
Post #392442 20th Jun 2016 11:49pm
peejay
No mine is January 2009 so not that model so I don't have that option, is there another way to do it?
Post #392560 21st Jun 2016 9:11pm
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
Hi i just noticed this topic and similar was happening to me but my seat was moving as well, every time i got out id come back to a different driving position, then one day i realised it was my fat arse hitting the memory buttons on the side of the seats (the plastic bit was broke and bending down and pressing buttons)
Post #409632 17th Oct 2016 3:55pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Not sure I would have volunteered that information Whistle 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #409645 17th Oct 2016 5:07pm
miggit
Shocked ^^ sounds like that's oozing too much information Rolling with laughter Rolling with laughter
The auto tilt / slide steering wheel is a novelty and in true Range Rover tradition it will brake down, not a matter of if, but when Shocked Mine worked when I first got the car... then after 6 months of so it would have the odd hiccup, and now it doesn't work at all Shocked But at least it's stopped whirring away when I remove the key Very Happy Having lived without it for for best part of a year now, I've come to the conclusion that my wallet can live without this function Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #409707 18th Oct 2016 6:48am
D34NO
My bad lol my arse isnt actually that fat its just as i get out and off the chair the broken plastic trim was hitting the buttons below and adjusting ......ill shut up lol
Post #409714 18th Oct 2016 10:16am
Brian
Just as an aside, my wheels in/out and memory has just started working again after not working at all since i got it. The up down tilt worked but never actually did anything unless I pressed the lever, and now for no reason at all the entire thing moves back and up when I turn off the ignition and comes back to my driving position when I switch on again Question Maybe it's because it's close to Halloween or something Rolling with laughter
Post #409720 18th Oct 2016 11:37am
miggit
Shocked working Shocked
Whistle don't get too used to it, as disappointment can be hard to contain..... Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #409745 18th Oct 2016 5:49pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
So is there a way to disable the function in a pre-tft car? 07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #433764 3rd Apr 2017 9:54pm
the GAP iidtool will disable it.. ... - .- -.
Post #433791 4th Apr 2017 8:12am
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I found it best to disable this function with IID. The motor going in/out/up/down everytime you get in and out seemed to Censored it off...Much better now Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #433798 4th Apr 2017 10:35am
agreed, i've done this with all my FF's..the whirring motor sound is a bit off putting, maybe if it was silent it wouldn't be so bad.. ... - .- -.
Post #433800 4th Apr 2017 11:15am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
I see this thread is a few years old but my '09 is also doing this.
I was hoping it was a simple issue of some type of calibration. Like with the window auto up/down you have to tell the controller the top and bottom positions (learning the locations).
Unfortunately I was unable to find any reference to this in the service manual.
Maybe someone in the past few years has figured out how to fix this issue! I don't have the IID tool yet but should in a few days (it just got shipped today).
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #575525 8th Dec 2020 10:15pm
winaje
United States 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Holy thread Necro Batman... I know, I'm sorry...
Can someone please tell me the exact IID CCF setting to disable this auto movement everytime you turn the key on and off?
Thanks
Post #686296 23rd Feb 2024 3:37pm
