![]() | Home > Technical (L322) > Adding Oil to Gearbox |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
If you have a search on here there are a few articles on gearbox oil change, also look in the wiki on the top right of the page lots of info in there.
norman1979 Member Since: 30 Mar 2017 Location: London Posts: 5 ![]() ![]() ![]() |
Thanks Dave.
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Dr Tranny instant shudder fix is like 50ml, if you adding couple tubes of this you should be fine.
Thanks for the reply.
The range rover gearbox is not checked by oil coming out of the filler hole (like 95% cars), so you have most likely over filled it.
Uh oh |
Reading a few posts on here the gearbox oil is full when it starts leaking out of the filler plug as long as the engine is on.
Seems should be ok, if the engine was running and had little drop coming from fill hole.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
You either had a leak or it wasn't filled correctly in the first place by somebody who has repaired or serviced it.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
norman979, here yo go...
Oh and don't use anything other than Mobil LT71141 to top up or it's direct equivalent or you are pooped.
