Home > Technical (L322) > Adding Oil to Gearbox |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 |
If you have a search on here there are a few articles on gearbox oil change, also look in the wiki on the top right of the page lots of info in there.
30th Mar 2017 1:47pm |
norman1979 Member Since: 30 Mar 2017 Location: London Posts: 5 |
Thanks Dave.
31st Mar 2017 8:23am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Dr Tranny instant shudder fix is like 50ml, if you adding couple tubes of this you should be fine.
31st Mar 2017 4:40pm |
Thanks for the reply.
1st Apr 2017 9:03am |
The range rover gearbox is not checked by oil coming out of the filler hole (like 95% cars), so you have most likely over filled it.
1st Apr 2017 9:25am |
Uh oh .
1st Apr 2017 6:04pm |
Reading a few posts on here the gearbox oil is full when it starts leaking out of the filler plug as long as the engine is on.
1st Apr 2017 6:19pm |
Seems should be ok, if the engine was running and had little drop coming from fill hole.
1st Apr 2017 6:40pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
You either had a leak or it wasn't filled correctly in the first place by somebody who has repaired or serviced it.
2nd Apr 2017 5:02am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
norman979, here yo go...
2nd Apr 2017 6:01am |
Oh and don't use anything other than Mobil LT71141 to top up or it's direct equivalent or you are pooped.
2nd Apr 2017 6:57am |
