Home > Technical (L322) > Adding Oil to Gearbox
norman1979
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi guys,
Newbie here over from the RRS forum. I have recently acquired a FF 2003 4.4 Vogue. I have noticed an ever so slight vibration under load and wish to add Dr Tranny instant shudder fix.
On the RRS, it can be done from the engine side. Is this possible on the FF also? I had a look and I am struggling to find the location to do this?
Also, is it easy to check the gearbox oil on these?
Post #433192 30th Mar 2017 10:55am
Dave 67
England 2004 Range Rover Vogue 4.4 V8 Java Black
If you have a search on here there are a few articles on gearbox oil change, also look in the wiki on the top right of the page lots of info in there.
Here's a link to the wiki post http://www.fullfatrr.com/forum/post166361.html#166361 2004 4.4V8 Vogue
BMW 330CD
BMW523i
Escort Mexico MK1
1974 airportable series 3
Post #433216 30th Mar 2017 1:47pm
norman1979
Thanks Dave.
Is it possible to overfill the gearbox?
Post #433311 31st Mar 2017 8:23am
b348xyx
Dr Tranny instant shudder fix is like 50ml, if you adding couple tubes of this you should be fine.
to add this stuff you will need to jack up the drivers side uk so the car is leaning over, and loosen the fill bolt a little.
start the car while on the jack stands and remove fill plug, pour in the stuff your using and close within at least 3-5mins as when the gear box oil get hot it will start pooring out the fill plug.
need to do this when engine is stone cold..
Note though what your doing will only help short term, if you torque converter is making noise it needs replacing. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #433348 31st Mar 2017 4:40pm
norman1979
Thanks for the reply.
I wanted to check if the oil was low or not. I put it on the ramp with the car switched on. Opened the gearbox oil filler nut and ended up putting in 3.5 litres before it started to come out of the filler hole Shocked Shocked Shocked
Is that pretty low?
Post #433431 1st Apr 2017 9:03am
b348xyx
The range rover gearbox is not checked by oil coming out of the filler hole (like 95% cars), so you have most likely over filled it.
Need to read some of the guides to changing it correctly. they are easy to overfill. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #433433 1st Apr 2017 9:25am
norman1979
Uh oh Shocked Shocked .
I read most of the guides and it was related to an oil change rather than a topup. Is it actually overfilled? It drives as smooth as its been since I have had it
I read on another forum that its not possible to overfill the 5 Speed gearbox
Post #433490 1st Apr 2017 6:04pm
norman1979
Reading a few posts on here the gearbox oil is full when it starts leaking out of the filler plug as long as the engine is on.
I cycled through the gears to ensure the oil was in the TC and also ensured it was on level ground.
Still likely to be overfilled? There was abit of thump in the gear changes occasionally and this has now gone.
Post #433494 1st Apr 2017 6:19pm
b348xyx
Seems should be ok, if the engine was running and had little drop coming from fill hole.
although if you gearbox oil was the low must been leaking somewhere. as adding 3.5 litre is alot.
ZF Automatic gearbox: ⇒ Refill 6.0 litres ⇒ Fill from dry 9.9 litres 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #433495 1st Apr 2017 6:40pm
holidaychicken
You either had a leak or it wasn't filled correctly in the first place by somebody who has repaired or serviced it.
The procedure is in Rave and yes vehicle level engine running and transmission temp up to 50 degrees from memory and fill until over flows filler hole and cycling the gears.
Post #433525 2nd Apr 2017 5:02am
nino_nino
norman979, here yo go...
http://www.zf.com/global/media/medien_mast...145_EN.pdf
Post #433527 2nd Apr 2017 6:01am
holidaychicken
Oh and don't use anything other than Mobil LT71141 to top up or it's direct equivalent or you are pooped.
It wouldn't be a bad idea to do a complete oil and filter change at some point as the fluid would have been working overtime if it was that low. Only use an OEM filter if you do. Smile
http://www.opieoils.co.uk/pv-92049-mobil-a...0wodvUEGNw
Post #433530 2nd Apr 2017 6:57am
