Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 1 of 15 123 ... 131415>
GraemeS
I have fitted a new radar unit, new left steering wheel switch bank and made some CCF changes to enable ACC including with queue assist. Shortly after start-up the message 'Forward alert not available' occurs and any attempt to use CC causes the message 'Cruise not available'.
A permanent DTC U2101-00 (AF) 'Control module incompatible configuration' is set for the ACC module. I don't know if the DTC is set because the radar unit has yet to be calibrated or if the CCF is not correctly set. It would be helpful if someone with a MY11/12 4.4 TDV8 fitted with ACC and has a diagnostic tool (eg IIDTool or Faultmate Extreme) could confirm the following particular settings. The settings for a MY10 3.6 and a 5.0 might be different so not conclusive.
Collision mitigation by braking : GEN1
Forward collision warning : GEN1
Currently I cannot calibrate the radar unit. My Faultmate Extreme aborts with an error that may be due to the U2101-00 DTC or may be due to a Faultmate s/w shortcoming (the problem has been reported to BBS) and my IIDTool does not have the option to calibrate the radar unit.
Thanks for any help that can be provided.
Post #432222 23rd Mar 2017 11:14am
proser
Graeme,
give me a few mins and I'll pop out and get the details from mine. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #432229 23rd Mar 2017 12:03pm
Baltic Blue
I will try and help you if you give me better step by step instructions.
I am a novice with my new iid, but willing and keen to learn.
Mine is a late 2011 Vogue SE with adaptive cruise control. (4.4 tdV8 ) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #432230 23rd Mar 2017 12:09pm
proser
This is all I see for ACC with IIDTool
 Regards
Mark
2012 Westminster
Post #432271 23rd Mar 2017 3:50pm
GraemeS
Thanks for the replies. I somehow missed seeing the thread updates until just now - my apologies for not checking sooner.
An IIDTool will only show all the parameters if you have full ccf access and using the tool's latest beta version firmware. If full ccf access has been granted and the beta firmware loaded then there will be an extra option to show untested parameters when selecting ccf values. Following is what I have set.
Speed control – adaptive fitted
Adaptive speed control ECU – North America, Canada, Mexico, Australia
Adaptive speed control ECU – standard blockage level –40dB (perhaps should be BOTH)
Collision mitigation by braking – fitted
Standard speed control display type – Adaptive speed control full display plus priority messages
Speed control – ACC_QUEUE
Adaptive speed control indication in instrument cluster – enabled
Speed control – Adaptive speed control, stop and go
Collision mitigation by braking – GEN 1 (perhaps another option but tried them all yet the DTC still occurs)
Forward collision warning – GEN 1 (perhaps GEN 2 or GEN 3 but tried them all, matching the above GEN1/2/3)
Patrick at Gap Diagnostics has said they will look into the possibility of adding the option to calibrate the radar.
Post #432851 27th Mar 2017 11:44am
rar110
That sounds great Graeme. Thumbs Up ______________________________
Post #432905 27th Mar 2017 8:33pm
GraemeS
It would be great except that Patrick has advised that the radar unit is for a Jaguar which means that it was misrepresented in the ebay advert stating that it was LR029157, the RR/RRS version, which it cannot be. An attempt to reflash the firmware with the RR/RRS version failed.
Post #432924 28th Mar 2017 3:54am
GraemeS
Having determined that the wrong radar unit has been acquired, instead of CCF parameters I need to know the ecu assembly and hardware details for the ACC module as shown by an IIDTool Ecu Infos display to allow a correct module to be acquired. The details below are from the Jaguar radar module.
CCM-Cruise Control
Assembly (F113)
CX23-9G768-AD
Hardware (F111)
BW83-14D047-AA
The latest probable assembly number that I've spotted is BH32-9G768-AD.
Post #432931 28th Mar 2017 8:31am
proser
from mine :
 Regards
Mark
2012 Westminster
Post #432937 28th Mar 2017 9:37am
GraemeS
Thanks Mark. However that's not ACC, which is CCM-Cruise Control and appears following BCM-Body Control in the list of ecus.
Post #432938 28th Mar 2017 9:51am
proser
so you need this Very Happy
Also in the BCM it show's it as JAG Cruise Control
And this is why I gave the first screen shot with ACC. Regards
Mark
2012 Westminster
Post #432939 28th Mar 2017 9:57am
GraemeS
Thanks Mark, that's exactly what I need! I've already set the Jag parameter back to ACC until I get it working then will change to activate queue assist.
I'm taking steps to recover the cost of my current radar module and will buy a correct one this time, relying on the assembly number shown on the label rather than a part number that isn't on the label. There's a couple available now so will buy one shortly.
Thanks again,
Graeme
Update: Gap Diagnostics has provided a firmware re-flash to the correct firmware. Setting calibration mode will be the next and hopefully the last step.
Post #432941 28th Mar 2017 10:28am
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
Hiya GraemeS
I also retro fitted ACC to my vehicle a little while back and had some trouble figuring out everything that I needed to change in my Vehicles CCF to get it working properly.
In the end I found a vehicle that had CCF installed from factory, got its VIN and used the Genesis's quite smart compare functions to highlight the differences. One of the most unusal i recall was a parameter labeled CMbB that I now know stands for Collision Mitigation by Braking.
After making almost half a dozen changes, I now have my retro fitted ACC fully working as it should.
Hope this helps 2003 4.4 HSE
Post #432968 28th Mar 2017 3:36pm
Rob99
Great topic Graeme Thumbs Up
Is all the wiring and connectors for the various ACC hardware already installed or did you also have to purchase additional wiring looms etc? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #432971 28th Mar 2017 3:42pm
BBS SPY
I detailed my personal experience and CCF changes on this thread
[url]http://www.disco3.co.uk/forum/topic74744.html?highlight=ACC&start=120 [/url] 2003 4.4 HSE
Post #432975 28th Mar 2017 4:05pm
