Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Graeme,
23rd Mar 2017 12:03pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
I will try and help you if you give me better step by step instructions.
23rd Mar 2017 12:09pm |
This is all I see for ACC with IIDTool
23rd Mar 2017 3:50pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
Thanks for the replies. I somehow missed seeing the thread updates until just now - my apologies for not checking sooner.
27th Mar 2017 11:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
That sounds great Graeme. ______________________________
27th Mar 2017 8:33pm |
It would be great except that Patrick has advised that the radar unit is for a Jaguar which means that it was misrepresented in the ebay advert stating that it was LR029157, the RR/RRS version, which it cannot be. An attempt to reflash the firmware with the RR/RRS version failed. |
28th Mar 2017 3:54am |
Having determined that the wrong radar unit has been acquired, instead of CCF parameters I need to know the ecu assembly and hardware details for the ACC module as shown by an IIDTool Ecu Infos display to allow a correct module to be acquired. The details below are from the Jaguar radar module.
28th Mar 2017 8:31am |
from mine :
28th Mar 2017 9:37am |
Thanks Mark. However that's not ACC, which is CCM-Cruise Control and appears following BCM-Body Control in the list of ecus. |
28th Mar 2017 9:51am |
so you need this
28th Mar 2017 9:57am |
Thanks Mark, that's exactly what I need! I've already set the Jag parameter back to ACC until I get it working then will change to activate queue assist.
28th Mar 2017 10:28am |
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 |
Hiya GraemeS
28th Mar 2017 3:36pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1420 |
Great topic Graeme
28th Mar 2017 3:42pm |
I detailed my personal experience and CCF changes on this thread
28th Mar 2017 4:05pm |
