Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 |
according to the WM you can disconnect this pipe to drain the oil rather than using a vacuum..
25th Feb 2017 5:53pm |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 |
Thankyou. I looked at that shall give that ago.
25th Feb 2017 6:10pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
If you do drain the oil this way, please take some photos and add any tips to this post.
25th Feb 2017 6:19pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
I have recently bought a 'Draper Expert' vacuum pump from machine mart. 95.00. Its a 10 litre capacity manual or pneumatic and is so easy to use. Plugged in my compressor and away it went - extracted 9.5 litres i about 2 mins. An oil change on my 4.4TDV8 took 10 mins and was so simple.
25th Feb 2017 6:32pm |
Hi Ajac
25th Feb 2017 6:50pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Any reason 3k oil changes? Seems pretty frequent Cheers, Greg
25th Feb 2017 7:55pm |
Macca PM sent but essentially the Draper comes with a flexi tube that fits snuggly over the (6mm?) engine outlet.
26th Feb 2017 10:18am |
A nice treat for your 4.4 !
26th Feb 2017 10:27am |
... and having serviced Marine diesels for quite a few years with no sump drains (normal for marine), I can say that the right oil extractor is worth it's weight. So if there is one that works well stick to that.
26th Feb 2017 10:30am |
MrChubba Member Since: 03 Dec 2017 Location: Penrith, Cumbria Posts: 4 |
Hi Ajac,
31st May 2018 8:53am |
My job for today, but note these pictures relate to the 4.4tdv8, as per the original thread title.
31st May 2018 1:07pm |
now I know where to come for my next oil change
31st May 2018 1:17pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Mike, I see your oil level is at "max" and the engine temp. is just warm, when engine reaches full working temperature oil level is going to be two maybe 3 nocis over "max". get the engine to working temp. and check the oil level ( wait minimum of 25~30 sec. for level to give right reading).
31st May 2018 1:34pm |
Cheers Nino,
31st May 2018 1:57pm |
