Home > Technical (L322) > 4.4 tdv8 12MY restricted Performance |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 488 |
Hi there, was wondering if anyone has experienced or could shed light on this.
28th Dec 2016 8:37pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3764 |
It might be worth getting the turbo air change over valve checked.
28th Dec 2016 8:55pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Could it be slight degradation / split in one of the hoses from intercooler to inlet manifold? They're well known for failing (on 3.6 TDV8, anyway - can't see why it would be any different on a 4.4). The top two hoses are fairly easy to get at and inspect. My thinking being that a split might only open up under pressure, which would explain 3k trouble-free miles between problem.
28th Dec 2016 9:49pm |
Hi Steve, good point, although it is used hard between the 3k miles so i am not sure as its not a consistent fault. will check the hoses. Cheers
29th Dec 2016 10:57am |
JST,
29th Dec 2016 2:03pm |
thank you Cheers
29th Dec 2016 2:48pm |
still does it, hoses are good.
15th Feb 2017 4:44pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I had a similar issue last year whilst in France and it turned out to be a cracked inlet manifold. The French mechanic demonstrated it by standing on the accelerator whilst I held my hand over the manifold. Lots of air escaping from the split manifold. It appears the split only caused an issue when the car was on a long climb with the caravan on the back, I.e. Under load. |
15th Feb 2017 6:30pm |
cheers Buzz, that has been suggested previously and your comments help reassure this. was that on a 4.4? i am aware of is it being a problem with the 4.4s Cheers
15th Feb 2017 7:18pm |
Hi James, yes, a 4.4 |
15th Feb 2017 7:22pm |
thank you. Cheers
15th Feb 2017 8:16pm |
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 |
Hi JST,
4th Feb 2019 4:58pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Hi Tony,
4th Feb 2019 5:52pm |
hello,
4th Feb 2019 10:44pm |
