![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Probably in a different position on the diesel ?
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
The BMW 740d stat is an 88 deg version of the stat that fits the M62 engine, just doesn't have the heater, otherwise it's a straight swap with no need to mod anything which is what I wanted. Anyway I took the induction pipe off as well as the engine cover, still managed to damage myself. Mind you I usually do when I have a spanner in my hand. Drives:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
Skin heals... at least your engine will love you for it...!! |
This is very true |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
After trying in vain to find a cheaper alternative to the conversation kit the dollar/pound exchange rate improved and I ordered mine. I was also concerned that the higher temp was a positive design and shouldn't be messed with. After lots of reading I am convinced it will not do anything negative including decreased fuel mileage. I have a pin hole radiator leak that I was going to fix at the same time I changed the thermostat but I am curious to see if the drop in pressure will have any affect on the rate of leak. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1555 ![]() ![]() |
The change from a 200kPa cap to a 140kPa cap certainly reduced my coolant loss. I still haven't got around to fitting the new radiator I bought before Christmas. Ron B. VK2OTC
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
My IID tool brings up this fault code. Does this mean I have the lower temperature stat? Not Galway but Balmoral green actually 148,000 miles |
Not necessarily. You could have a faulty circuit/thermostat. Have you visually inspected the connection? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
I agree with the Doc, it's either you do have the mod or you have a faulty circuit within the 'proper' thermostat.
RAVE says the thermostat heating element is triggered under load. Does this mean when you accelerate quickly? If so then maybe that circuit could be used to trigger a warning light such as flashing $$$ or £££!. Maybe a recording of sirens or McLaren P1? |
Will have a closer look tomorrow, thanks Not Galway but Balmoral green actually 148,000 miles |
I did the kit today. One thing to mention at least for me is that allen bolt head use. Although the. Standard head bolt will go on 99% of the way there is a bolt head off the block that makes getting that last 1% tightening impossible with the 1/4 drive 10mm socket. The Allen head was a must for me to get it tight enough. |
That's interesting... mine was fine with the four normal bolts, mind you I did use a thin wall deep 10mm socket so maybe that's the difference.... |
Yes I'm sure socket wall thickness is the key. The 1/4 inch drive socket is smaller than the 3/8 but mine was just not enough. |
