Home > Maintenance & Mods (L322) > key fob buttons
Page 3 of 4 <1234>
Avi
2006 Range Rover Vogue Td6 Alveston Red
SteveMFr wrote:
Hey Gaz,
The symptoms you describe are when the chip is missing altogether - did you replace it? It sits under the circuit board next to the buttons. Looks something like this:
Only about 8-10mm long, 4mm wide and 3mm thick. It's easy to miss because it doesn't look like anything electronic or even anything worth saving. I hope your trash has not yet been picked up Shocked
i had the same problem until i noticed the tiny chip on the lounge floor ! Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #42506 16th Dec 2010 9:21pm
Avi wrote:
SteveMFr wrote:
Hey Gaz,
bet i have lost it! Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #42516 16th Dec 2010 10:31pm
Midgie raker Big Cry Big Cry
No Mick, don't give them any clues Rolling with laughter Rolling with laughter
Post #42517 16th Dec 2010 10:43pm
SteveMFr & AVI,
Where exactly in the key fob does this chip attach to the board?
many thanks
Gaz
Bin sorting tomorrow - great Sad
Post #42518 16th Dec 2010 10:44pm
Avi
Gazellio wrote:
SteveMFr & AVI,
many thanks
Gaz
it doesnt attach to anything. it just sits inside the fob. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #42519 16th Dec 2010 10:49pm
bloody silly so it just drops out Evil or Very Mad
thanks anyway i presume its coded only to work with its owbn car...
Post #42520 16th Dec 2010 11:02pm
Avi
yes, mine must have just fell out. couldn't see any sign of it being glued in.! Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #42522 16th Dec 2010 11:09pm
SteveMFr
Site Sponsor
As Avi says, not attached to anything. It just sits next to the rubber button inlay (upper left with the key blade pointiong upwards) under the circuit board. There should be a pic with the instruction sheet that came with the buttons.
Do some searching! It has to be somewhere! Howbout the dustbag in the vacuum cleaner?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42523 16th Dec 2010 11:36pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
bummer gaz... Sad
so if that little chip sat in the glove box you could run two ebay keys.. Idea Question 2004 black Vogue TD6
Post #42529 17th Dec 2010 12:05am
letsavit2 wrote:
bummer gaz... Sad
key has to be within inches to activate - listen for the click as the key goes in...
chip may have been stuck to the old damaged rubber button panel - bins in minute Big Cry Big Cry
Post #42541 17th Dec 2010 7:45am
SteveMFr
Site Sponsor
I was really hoping for you. I saw that you had posted here and wanted to read 'FOUND IT!'
Neutral
Do another search on the floor around where you replaced the buttons. I once sprang a steel ball out of a synchro for a Austin Healy gearbox about 5meters from where I was working - and found it. It was only 1/4th the size of your chip...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42600 17th Dec 2010 5:57pm
Neutral
THanks Steve,
I spent all morning going through two bin liners full of waste (youngest was sick the night before Big Cry ) with gloves on outside in -4 but to no avail I could not even find the discarded black rubber bits!!!
Looks like I am going to have to bite the bullet and order a new one at £187 + VAT F**K Crying or Very sad
Post #42603 17th Dec 2010 6:10pm
nbunney
Gaz
Ask for a discount.
Mine was less than that incl vat
Post #42608 17th Dec 2010 6:33pm
nbunney wrote:
Gaz
Ask for a discount.
Just ordered it at £167 inc VAT as a trader with local stealer.
Did you have to have the new key programmed (not synced but programmed) at the dealer and how much did they charge?
PS: I opened the good key and saw that the black chip sits under the board on the black rubber just as stated earlier in thread. As its stuck to the rubber its very east to throw it away when replacing the rubber so beware Embarassed
Post #43873 29th Dec 2010 3:37pm
nbunney
Gaz
Good 1 Thumbs Up same as I paid.
Programming - No not yet as the steller could not do it when I [icked it up, but wantred £40 to do it Censored
The parts guy did say that the odd time they did work straight out the box. Mine didn't Big Cry
Post #43909 29th Dec 2010 9:28pm
Page 3 of 4 <1234>
