Home > Maintenance & Mods (L322) > key fob buttons
Page 2 of 4 <1234>
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
thank you for the links, mine have the same problems Silencio's one
Post #41111 6th Dec 2010 11:17am
tommac22
i have contcated the seller this afternoon and had the last 2 he had from him- might be worth contacting him and enquire if he is getting any more stock!
Post #41162 6th Dec 2010 4:32pm
T24RES
I've got a set coming that i now dont need, if when they arrive somebody wants them at what i paid let me know. Ian
Post #41349 7th Dec 2010 6:20pm
T24RES
ARRIVED if you want them pm me! Ian
Post #41624 9th Dec 2010 4:51pm
SteveMFr
Site Sponsor
Mine have arrived as well. Def worth it!
Took a little while to cut the old buttons out and get rid of all the little bits in the slits as in del's pics. And looks and works like new. Well aside form the funky hatch release button design Laughing Makes me chuckle every time I look at it.
The seller is gonna get a great review from me.
I'll try'n post pics on the WE. Too lazy to dl from the camera tonight.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #41650 9th Dec 2010 8:50pm
I need 1 set!
Thumbs Up Thumbs Up Thumbs Up
Post #41651 9th Dec 2010 8:52pm
T24RES
Gazellio wrote:
I need 1 set!
pm sent Thumbs Up Ian
Post #41680 9th Dec 2010 10:57pm
Replied
Post #41684 10th Dec 2010 7:52am
T24RES
Gazellio wrote:
Replied
Sold Ian
Post #41779 10th Dec 2010 6:55pm
SteveMFr
Site Sponsor
Ok, here are some pics:
Before. Ugly, gummy blob buttons on left key, good oem key on right, replacement buttons in the middle.
After cutting out the old buttons. They are molded through the little slits around the perimeter of the holes. Bit of a PITA to get everything clean
Shiny new buttons. Did not do any addtl sealing as mentioned on p.1 of this thread as the key is not watertight to begin with.
Fit and finish is really good. Function is like new. The only differences are that the lock buton is slightly raised compared to oem, the hatch release design is funny, and the 'Land Rover' script goes in rather than being raised. Very good product, tho. We'll see how long they hold up.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #41983 12th Dec 2010 2:19pm
T24RES wrote:
Gazellio wrote:
Replied
Sold
Just received and fitted in minutes - very happy and thanks mate Thumbs Up
Post #42268 14th Dec 2010 10:37am
Since fitting the new panel the key must have lost power and will open the car set the seat but will not turn in the ignition.
I have tried the synchronise sequence:
Key in, position 11, key out,
1st key hold unlock while pressing lock 3 times, release unlock button - car locks go click, then
2nd Key hold nlock while pressing lock 3 times, release unlock button - car locks go click, then
key back in ignition turn to pos 11 then key out.
This works fine and both keys open the doors remotely and set the seat memory positions but the key with the new rubber panel is not always recognised by the immobiliser (although it does intermittently) any ideas?
Post #42480 16th Dec 2010 1:58pm
Land Rover Key Fob Synchronizing & Battery Change PDF
Here is a very useful document on all Land Rover Key Fob battery replacement and re-syncing procedures:
http://www.garyelliott.co.uk/ffrr/Key%20Fob%20Programming.pdf
Post #42485 16th Dec 2010 3:57pm
Warning opening the key fob risks damaging the numbered "Chip" at the front of the circuit board that connects with the key shaft and tell the immobiliser that its the right key. The key working in the ignition slot and turning off the immobiliser has no relation to the programming of the key to open doors etc detailed above!
Looks like I am going to have to buy a new key...... Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
New Key £186 + VAT Big Cry Big Cry Big Cry Big Cry
Post #42488 16th Dec 2010 5:29pm
SteveMFr
Site Sponsor
Hey Gaz,
The symptoms you describe are when the chip is missing altogether - did you replace it? It sits under the circuit board next to the buttons. Looks something like this:
Only about 8-10mm long, 4mm wide and 3mm thick. It's easy to miss because it doesn't look like anything electronic or even anything worth saving. I hope your trash has not yet been picked up Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42493 16th Dec 2010 8:01pm
Page 2 of 4 <1234>
