Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
+44C/111F today and, during an extended run on the motorway, the coolant temp (as per the ScanGauge II) didn't rise above 105 deg C.
18th Jan 2017 7:23am |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 |
Gentlemen,
19th Jan 2017 12:01pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Fook me, you didn't need to go that far just to change the thermostat ! |
19th Jan 2017 7:50pm |
Sorry, I lost the manual Mark Offringa
20th Jan 2017 2:16pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
I ordered the one from ebay... Will install this weekend...
20th Jan 2017 10:43pm |
I am interested too to see what the running temp is with an 88 stat as mine runs at around 93 degrees with the 80.
21st Jan 2017 7:50pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
I tried an 80, 87 and 90something...
21st Jan 2017 11:07pm |
That's makes sense, I think the natural running temp is around 90-95 degreees |
22nd Jan 2017 9:38am |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
You know how that goes. One thing leads to another and you starts saying " while I'm this far I might as well..." |
23rd Jan 2017 2:14am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Apologies if this has been discussed elsewhere, but isn't there a direct replacement lower temp thermostat available from BMW? One where there is no need to modify the housing? Accepting it may well be more expensive. Drives:
23rd Jan 2017 8:41am |
Yes, on page 3 of this thread, MarkNL and myself have ordered them and still have mine as i ordered the 80 deg mod instead |
23rd Jan 2017 9:44am |
Ah yes, so it is Andy, thanks. So, the BMW OEM NUMBER 11512248542 is an 88 deg unit that is a direct replacement part for the standard unit (LR part No. PEL000060, which is a 105 deg unit)? I note you refer to a blanking disk for the heater, is this required for the L322 application?
23rd Jan 2017 12:27pm |
this is what you need
23rd Jan 2017 8:22pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Delighted to see this bumped tonight as I'm ordering a stat.. so the vemo one is a straight fit no alterations .. holidaychicken.. off topic matey but how did your investigations go regarding the head gasket issues? |
23rd Jan 2017 8:57pm |
